My patience has paid off, for I am now the new owner of a 2002 R1150R, in Atlanta Blue with the yellow seat. At least I think it's Atlanta Blue, a pale blue metallic.
It's a non-ABS model, complete with side bags, a couple of screens, some nice pin-striping and 66,0000 km on the clock.
I can hear the howls "spline failure, rear end failure imminent!"
I've added a Givi top box and as soon as I've burned through this tank of gas I'm going to add a Stebel Nautilus horn.
Some observations:
She's so easy to ride! I like the way the engine torque comes in and matches so nicely with the gear ratios. Personally, I find the six-speed box great, top gear is very useable in normal use. Those who criticize it for being too tall should try a big V-Strom, where sixth is almost unusable below 120 kph.
Handling and suspension are fully up to expectations, too.
The seat's a nut-cracker isn't it? I shall be looking into the after-market for something less stressful for the boys. Perhaps it needs time to adjust to me, the previous owner was a lady.
The only downer has been the tool kit. I went to check the plugs and, using the knowledge I've gained on this Board, I used the OEM plug socket and tommy bar. At least I would have if the tommy bar had fit, but it is crimped at both ends and will not go through the hole in the socket. Am I missing something? Yes, I am, an un-busted screw driver. My bad.
So there we are, a new machine to pile the miles on, spend some farkle-funds on and enjoy for what I hope will be many years.
Anybody want to buy a nice 2004 V-Strom 1000???
Cheers,
Tony
