What is this for???
Soliton
What is this for???
Post by Soliton »
Hi Guys,
Forgive the noob but I am trying to work out what something is for.....
It is:
1 - Cylindrical - rubberised 50mm long, 20mm diameter.
2 - On the right hand side of the bike under the rear sub frame at the point where the passenger peg loops meet the subframe.
3 - Wired up.
OK, I give up. What does it do, and if I don't use it can I cut it off and terminate the cables?
omg1010
Re: What is this for???
Post by omg1010 »
Photo?
DJ Downunder
Post by DJ Downunder »
Would it be the clutch bleeder grub screw?
http://ep.yimg.com/ca/I/yhst-1510226021 ... 3209426825
atown154
Donating Member #: 996
Post by atown154 »
Are you talking about the charcoal canister ?
jas
Post by jas »
As DJ said, it is for bleeding the clutch, there is a grub screw in the end and is housed in a foam of sorts and zip-tied out of the way. Pull the grub screw and insert a bleeder and you're good to go for changing the clutch fluid.
2004 Roc.
kantuckid
Post by kantuckid »
atown154 wrote:Are you talking about the charcoal canister ?
Just to get you headed right: 25.4mm= 1"
Xdot
Post by Xdot »
Just don't touch it, whatever you do!!!
2017 Husqvarna 701
2007 Husqvarna TE250
2004 BMW Rockster
Soliton
Post by Soliton »
Thanks guys,
As always you are spot on the money!
As advised I won't remove it.
Sol.
That is the "time delay trigger" for the clutch spline self-destruct mechanism. It is a top secret install done by Venusian Martians.
theshowmecanuck
Post by theshowmecanuck »
towerworker wrote:That is the "time delay trigger" for the clutch spline self-destruct mechanism. It is a top secret install done by Venusian Martians.
I thought they removed that on a safety recall. :-k :^o
