Is this unusual wear?
Sunbeemer
Donating Member #: 593
Re: Is this unusual wear?
Post by Sunbeemer »
April's fools there.
Got me! :lol: Good one, John! =D>
Biff's R , I'm riding BT-023's now; traction's OK, and I got 7700 miles out of my last BT-03 rear. My current front tire has 4200 on it and looks pretty good for another 4000+ more. Based on John's tire longevity, I suspect that even considering the additional $$, the PR3's are a better value ($/mile-wise). :?:
ADIOS!
Biff's R
Donating Member #: 289
Post by Biff's R »
My mileage has been pretty consistent between the PR1, PR2, and Z6. And my guess is that the PR3 will do about the same. I had the BT-021 and only got 5k miles out of them. So I am hoping the 023s last as long as the PR1. I don't think that I will ever get 14k on any set of tires.
Jeff (lifer #289)
'17 F800GSA
'04 R1150R
Dr. Strangelove
Post by Dr. Strangelove »
Hi, Jeff
That's cuz you have those fine Ohio roads. We have next to nothing like that here in La. Lots of my miles, unless I am one of my trips, is riding the center compound and that is harder. And it's riding city streets. I got 10+ out of the rear.
'09 Schwarze Blanche DuBois
Boxer
Post by Boxer »
It's like that worn out shock way back when...You beat anorexia!
Biff's R
Post by Biff's R »
Very true. Extra downforce means more friction and wear on the tires. :lol:
Jeff (lifer #289)
'17 F800GSA
'04 R1150R
Dr. Strangelove
the final tally on the front was 14481! There were some miles left on it, but I needed to change because a ride is coming up. It was noticeably lighter than the replacement. The rear had about 10,500 when it was replaced
And, while at Baton Rouge BMW last weekend I saw a flyer for the PR3s. There were graphics showing the pressure points during turns vis a vis the sipes and treads. From those pictures my wear is not unusual at all, it is the norm.
Also, while the rim was bare, with all previous weights on, I put it on the marc parnes balancer. Removing some weight and adding some, I balanced the naked wheel. Then I installed the tire...
backwards :oops:
so I got to do it all over again. :-X
When I put it on the balancer it was pretty close to ideal, close enough for sure.
gregor
Post by gregor »
Very unusual wear. I got just 3500miles from my front Bridgestone Battlax BT021. Will be looking for a cheaper one next time.
Dr. Strangelove
gregor wrote:Very unusual wear. I got just 3500miles from my front Bridgestone Battlax BT021.
I was referring to the pattern of wear, not the mileage. 3500, ouch. I think 14.4 is a lot, but I seem to get better mileage than many on the board. Probably related to our road surfaces here and lack of twisties unless I am on a trip.
Biff's R
Post by Biff's R »
Dr. Strangelove wrote: Then I installed the tire...
backwards :oops:
That sucks. The abs ring has saved me a couple of times from doing the same thing.
Jeff (lifer #289)
'17 F800GSA
'04 R1150R
