Synthetic Transmission Oil ?
gregor
Post by gregor »
My gear shift was getting ever more 'characteristic'. I thought I'd try synthetic again. Been using some bulk mineral 80/90 GL5.
Now using a full synthetic 75/90 GL5. A noticeable improvement with less/no clunking or wrestling into neutral at junctions. I'm aware of potential oil seal problems and will keep an eye out for leaks.
slowtorque
Re: Synthetic Transmission Oil ?
Post by slowtorque »
Excellent. Thanks for sharing. What brand synthetic?
Johnny
04 R1150R GONE
10 R1200R GONE
sjbmw
Moderator
Donating Member #: 263
Post by sjbmw »
Went to 100% synthetic for all lubes 2 years ago at about 30k miles.
The most noticible trait is the smoothness of shifting.
The entire bike smoothed out though and nothing is leaking.
mcmarcia
Post by mcmarcia »
I have been running full syn castrol or mobil in my tranny and rear end for years now, works great w/smooth shifting and no leaks.
04 BMW R1150RA
92 Yamaha Virago 1100
95 Yamaha Virago 750
gregor
Post by gregor »
I admit to looking for the cheapest known brand on Amazon. Found a 5 litre container of Comma, the kind of oil you find in a trade counter place.About £29 for 5 litres delivered IIRC.
No idea what the SX prefix means? I now realise that I bought semi-synthetic because of the seal worry.And it works fine.
The Comma Gear Oil has been specially formulated to the SX75W-90 specification. The gear oil should be suitable for 75W-90, 80W-90 or 85W-90, but please check your user manual for the specification you require.
Ol' Jeffers
Post by Ol' Jeffers »
Comma Oil is good stuff.....That's who makes Halford's branded oils.
They've been around for almost 50 years! No worries with Comma
as long as you use the correct grade.
OJ........everybody's pal!!
gregor
Post by gregor »
Thanks to the recent spate of discussions I've learned to shift even more smoothly.
I now pre-load the gear shift going up and down the box and adopted the technique mentioned elsewhere of only pulling the clutch lever in half way while riding along.
Changing fast using the above method works great when on the move. Obviously moving away from a standstill needs full clutch disengagement and clonking into neutral at a standstill is still a noisy PITA.
bmwdave52
Post by bmwdave52 »
I've been using Amsoil 75W-140 Severe Gear fluid for many years(8) now with very good results. Well worth the extra $$.
"When life throws you a curve lean into it"
Proud member since 2001; #17(Life)
gregor
Post by gregor »
I don't know. Recommended for Harleys you know. [-X
sjbmw
Moderator
Post by sjbmw »
bmwdave52 wrote:I've been using Amsoil 75W-140 Severe Gear fluid for many years(8) now with very good results. Well worth the extra $$.
Love the Amsoil 20W-50 too. It is expensive, but it's good stuff. Especially in the heat.
Ton1959
Post by Ton1959 »
I use the Castrol MTX synthetic SAE 75W-140 and that oil did improve the gearchange a lot.
