Hi!
I want to buy one a-arm for r1150r but is cant found it...
Somebody can help me in this problem? If you have one workable or you found one for sale please write me...
Or somebody tried to use other a-arm? For example r1200r or r1150gs...
Thanks...
A-arm problem
Re: A-arm problem
What's an a-arm ?
Re: A-arm problem
I assume the OP is talking about the front telelever. A-arm or wishbone is what automakers call their control arms for their suspension.acejones wrote:What's an a-arm ?
That being said, Beemerboneyard has one right now. http://www.beemerboneyard.com/teleleveraarms.html
2002 BMW R1150R
2004 Honda CBR600RR
2006 Kawasaki KLX250S
2008 Ducati Hypermotard
1996 Ducati 900SS
2004 Honda CBR600RR
1996 Ducati 900SS
Re: A-arm problem
E-bay?
02 R1150R Black
02 R1150R Black
Re: A-arm problem
The A-Arm of the R1150R (Rockster uses the same but in ferro color) is rare like the famous blue mauritius. You have to be patient and keep trying everywhere. But chances are slim to find a used one. You could however also use the a-arm of the R1100R/RS/RT/GS or 1150GS - it looks ugly but it can be used. In this case you need to a-arm as well as the long axle which bolts the a-arm to the engine as well as the locknuts and shims being used for the particular a-arm (it wont work with the axle for the R1150R a-arm!).
Or you go see your stealer and shell out mucho $$$ and buy a new one ...
Brgds
Oliver
Brgds
Oliver
Re: A-arm problem
Yeah, I know that. I just never heard the term used on a motorcycle.Oilhead wrote:I assume the OP is talking about the front telelever. A-arm or wishbone is what automakers call their control arms for their suspension.acejones wrote:What's an a-arm ?
Re: A-arm problem
The whole set-up on the oilhead is called telelever and the a-arm is just the a-arm. By the way beemerboneyard does not have a R1150R a-arm (tubular). They just have the odd sheet-metal a-arms used on the 1100 and some 1150 models. Those a-arms are usually cheaper to get via e-gay.
Brgds
Oliver
Brgds
Oliver
Re: A-arm problem
If you find an a-arm and have to remove the ball joint, you'll need a 1-13/16 socket. Funniest thing, I just happen to have one. I'll sell it to you for 50% of what I paid - $18 (plus shipping). It even has an adaptor to mate it to a 1/2 inch drive wrench. You'll have to heat the arm before removing the ball joint.
Pls reply to [email protected] as I don't watch this site very closely.
