The Bike came naked (no accessories) and since it came with no service record I did the following:
Change the engine oil and oil filter
Change the spark plug
Check the brake pads and discs for wear
Lubricate the stands, lever pivots and cables
Check the gearbox oil level
Check the final drive oil level
Check the tightness of all nuts and bolts
I plan on doing 2 day tours every other weekends and wonder what else I should do to prepare for those trips.
I have purchased a parabellum windshield, and ordered bar backs, and even took my seat to a local upholster to trim it down around 1 inch so I can firmly and confidently be flat footing on stops.
