jasondo wrote:Any place special as to where to mount the relay?
wherever it fits. my bike hasn't got the ABS module so there's plenty of room under the tank.
Relays are fairly simple, so robust, just don't stick it somewhere it'll get too hot.
I pulled power from a fused 10 ga wire that I added, coming off the battery to a relay. The relay signal wire comes from the light switch. I tucked the relay under the insturment panel ( Rockster). I also made a terminal strip for ground that is under the dash. The ground wire for this goes to the battery.
