It has been a while since I visited this board.
It looks like my ABS unit took a dive. It was fine up till now. New battery did not help
ABS light will be blinking 5 times and the warning light starts blinking together with the ABS light.
So.... How do you guys determine that servo unit is bad?
Did anybody ever solved the problem by flashing the whole system?
It looks like I will be looking for TowerWorker or SweetMark for the help to remove my ABS.
P.S. there are 2 blue relays in the fuse box. They are both the same, but if switched (rotate) them the ABS clicking sound is gone.
Thanks.
