Sounds like marbles rattling around in the engine
dickhein
Post by dickhein »
Any thoughts? My 2004 1150R fresh from it's 6k service makes some horrible sounds. When I accelerate up to anything over 3000 rpm and back off the throttle, the engine sounds like marbles rattling around. It only happens when the throttle is decreased and never under 3000. Oddly, the sound is not noticable when I wear my helmet, which is most of the time. During the 6k service, which I had done 1500 miles from home, the mechanic that road tested the bike wore his helmet. He may never have noticed. Meanwhile...
__________________
Guest
Post by Guest »
I believe the sound is from your Piston.
bakernks
sounds
Post by bakernks »
First guess is detonation. I'd definitely ride this bike less if at all until it's sorted. I'd check the simple stuff first. Since it was recently serviced, possibly some of the things they touched weren't secured properly. Make positive sure that the spark plug caps are actually snapped all the way on. Pull them and seat them back on yourself if this is something you're comfortable doing. Look to see if the TPS box, the 2" square black box on the LEFT throttle body is still secured, and the two screws holding it "on setting" still are cemented with the blue tattle tale paint dabs. Slipped TPS or loose spark caps could be a cause of these symptoms.
Detonation can seriously damage an engine. Sure, it might not be detonation, diagnosis over the internet is iffy. Get this sorted asap.
rdsmith3
Donating Member #: 74
Post by rdsmith3 »
Could be pinging from bad gas or too low octane gas, but I am no expert. Get back there ASAP.
2002 Atlanta Blue
Lifetime Member #74
zweige
marbles
Post by zweige »
I had a similar problem and it turned out to be a bad fuel pump.
Lance1150
Post by Lance1150 »
I had the SAME thing recently, it turned out to be several marbles. Nobody could explain that to me, they just said "Sometimes we find pens and pencils in there, mostly office supplies". They were VERY surprised at the marbles. Get it looked at quick.
03' Black Roadster
Southern California
NCRoaster
marbles
Post by NCRoaster »
I knew a guy who once had an 1150GS that made that sound when he accelerated. His problem was the mechanic replaced the timing chain tensioners with the part originally specified instead of the one with an updated part number. The oil pressure is controlled by vent holes in the tensioner and it turned out he had to have his engine rebuilt. I'm not saying this is your problem. I'm just repeating an experience I observed.
NCRoaster
JohnR
Post by JohnR »
To Lance1150,
I think you got confused in your post, above. "dickhein" was concerned about the his engine sounding like marbles were rattling around inside. It appears you were writing about the sound of marbles rattling around in your head. Marbles rattling around in an 1150 engine are BAD. Marbles rattling around in your hear are GOOD. When the marbles stop rattling around in your head, you've lost your marbles. :D
To dickhein,
I'm a new guy on the 1150. The BMW dealership that I want to use is a relative close four hour ride when compared to the 1,500 miles to the dealer you used. At least you are under warranty. Get it to a good BMW dealer. Good luck.
-John-
MikeCam
Centurion Moderator!
Donating Member #: 100
Wait
Post by MikeCam »
I think it sounds like you are reporting a cam chain noise. Cannot be certain from your brief description.
Might also be a loose header nut.
No puns intended above.
Guest
Post by Guest »
Dickheim:
You are saying the sound occurs when you de-accelerate and remove the load on the motor? That probably eliminates predetonation. I suspect either the cam chain tensioner or your sensitivity towards noisey boxer motors. Have your mechanic listen to it and fix it, or buy a good set of earplugs and maybe even a Valkrie.
dickhein
re: marbles
Post by dickhein »
Rattling marbles is probably a poor description--I'll never make it as a service writer. The loud tinny rattling sound occurs upon DEceleration and is instantaneous with release of throttle pressure. It only occurs when the RPMs are over 3000. It's definitely not ping.
Well there is one thing we know for sure.......we haven't determined wht it sounds like or the source of the noise on dickhein's bike.
Let's find out where dickhein makes home and maybe one of the gearheads close to him that frequent this site can be of assistance. :roll:
dickhein
Post by dickhein »
It's frustrating to not be able to adequately describe these engine sounds. However, I gather that no one else experiences noticable rattling sounds in the engine when the throttle is released as one does when shifting gears or just decelerating.
Ageing Disgracefully!
2004 R1150R Silver
1974 R90/6 White
Deans BMW
Post by Deans BMW »
Perhaps it is marbles....................... :P
I would suggest thast you go to a BMW dealer and let them listen.
Dean-O
Member #33
dickhein,
The conditions you describe necessary to make the sound, to me, points to a transmission problem. Above 3,000 rpm, the engine braking is stronger and the axial side load generated by the intermediate shaft's spur gears, together with a problem like a bad bearing can cause parts to touch, that never should.
Does it do it with closed throttle above 3,000 in every gear?
Does it do it reving the engine to 6,000 up/down quickly with the trans in neutral?
The answers to those 2 questions will tell you if it's the engine or trans.
dickhein
More on the marbles
Post by dickhein »
Took the bike to the dealer. He agrees there is something there, perhaps the alternator belt. He said it can wait til the 12k service. We'll see...
2004 R1150R Silver
1974 R90/6 White
NCRoaster
Warranty
Post by NCRoaster »
dickheim,
Just make sure that 12,000 mile service happens while your bike is still under warranty. Not that I'm being cynical or anything. It just sounds like you're getting bad advice. If your bike has an inappropriate noise in the engine it is likely that some kind of damage is happening. The R is a smooth, quiet, silky runner. If you're not getting that something needs to be fixed. Your dealer should address the problem now before it causes major damage. But that's just my opinion.
NCRoaster
Guest
Post by Guest »
Ditto NCRoaster, i.e. Don't let the cancer grow.
The dealer didn't give you the bike and let you pay for it untill after you have done 10K miles ! Right ?
Besides, the bike is still being broken in, anything happening inside the engine may affect that process, which means that problems may be developing that may not show till after, say, 20k mi. You may then see damage that developed very slowly.
Better be paranoid than sorry :(
Marbles?
Sounds to me like the wibblin pin came out of the wobblin gear. Or is it the other way around?
03 r
NCRoaster
an afterthought
Post by NCRoaster »
Just an afterthought dingle. If your dealer refuses to correct the problem, I suggest that you get some kind of documentation that proves you had brought this noise to the dealers attention. Later, if you have to negotiate with a regional rep or with New Jersey, you will have something to show that you asked to have the problem fixed before your warranty ran out.
NCRoaster
