Anyone replaced the catalytic converter with straight Y-pipe
Guest
Hi, this is my first post here, glad I found the board.
I took my cat off of my 2003 r1150r and replaced it with a straight Y-pipe and I did not notice any sound differnce but a big power difference. I really like it and I am getting a little bit better mileage with it. Anyone else do this mod?
1150RINSOCAL
logged me in guest
this is "1150rinsocal", the above post logged me in as "guest" - I'm getting used to the board
darthrider
Not a Y-pipe, but a StainTune collector box. Did this on my new 04 R bought this past May....here are some observations.
http://www.r1150r.org/board/viewtopic.p ... highlight=
j magda
TripleLifer Member 454
Deep in the OH wasteland...
Y pipe removal will reduce the restriction of the cat converter and allow the cylinders to fill up more. The Y pipe and the can that typically come with it will provide ~ 3hp increase to the rear wheel.
The increase will be mostly noticeable on the low end grunt and the roll on of the throttle. It will also make the throttle crisper.......normally there is a slight loss of MPG associated with this mod something in the 1 to 2 MPG.
And like Darth so stated the almost 20 pounds lost is a welcome relief to those like me that are "marketing size"
Straight pipes decrease the engine's output because one of the functions of a well desigbed exhaust is to use the sound waves to assist with the clearing of the spent gases from the cylinder, the process is called "scavenging"
Straight pipes have reduced internal voloume as opposed to a muffler and do not support the bouncing and expansion of the sound waves well....hence the loss in performance. On the other hand they do make a hell of a noise......can you hear me now.
Straight pipes do not all
Beemeridian
33
2015 Honda PCX150
2015 Honda PCX150
Changed to the Y pipe, K&N filter, and the Techlusion. Much improved throttle response, eliminated the surge BMW said I never had, not much different in sound. Gas milage? Never checked it but about the same miles/tank. Much less heat on feet and ankles in the heat of stop & go traffic. Have two r's, a 2002 & 2004 (both ABS), liked it so much did mod on both
Bernie J
2004 R1150R
2002 R1150R
1998 Ducati Monster 900
2004 Suzuki DR650
2004 Yamaha TTR250
2004 R1150R
2002 R1150R
2004 Suzuki DR650
2004 Yamaha TTR250
Guest
Probably. I've not heard of anyone doing this, but sure it could be done.Cant I just open the cat, remove internals, re-seal cat, keep my money and get most of the benefits???
You will need a good welder (machine) and a good welder (person) as carbon contamination in stainless steel welds will cause inclusions in the heat affect zone which will cause cracks. You could overcome this issue by passivating the material prior to welding.
The second problem is that this material has been heated and cooled so many times that is has heat treated itself into a very brittle crystal-like form of stainless steel with properties that can't be defined without a nice lab and lots of cash. Welding on this material might be successful, but heating and cooling it again (during use) would most likely cause more cracks unless you anneal it first and heat treat it again afterward.
In the end, the labor and "pain in the a$$" costs will probably outweigh the price of a new Y pipe or collector box.
Get your facts first, and then you can distort them as much as you please.
Mark Twain
Mark Twain
Beemeridian
44
2015 Honda PCX150
2015 Honda PCX150
Wow, i never would have thought the outer "shell" to be that thick, looks like you got your work cut out for you.
My guess is that because of the wall thickness your project cat won't have that "tinny" sound that the Staintune collector is said to have, allthough i'm sure it'll weigh a bit more. At any rate keep sending the pics, it looks like a good project.
Suzuki T500- learned on
Vmax- hang on
Klr650- muddy on
Softail- laid on
R1150R- moved on
Vmax- hang on
Klr650- muddy on
Softail- laid on
R1150R- moved on
Doug T
I was going to gut my cat as well. I do a lot of welding and such so I thought no big deal. But when I pulled the cat I noticed some plug welds on the sides of the cat . About 4 I think. Made me think that the internals are pretty well secured to the inside. You can't see anything looking in the openings so you can't just torch it out. It would require cutting the cat in half top to bottom, and then hopefully be able to cut the plug welds, gut it and weld back together. It could be done but it could also get ugly. So for now I'm positively not sure what to do. Hope this helps
