LED clear lens tail light
I've forgotten where I saw that tail light offered.
Anyone know off hand?
and at clearalternatives.com http://www.clearalternatives.com
#429 (in for life)
'06 Silver R1200RT
'04 Titan Silver R50R (3/05-9/10 was a good friend - RIP)
'06 Silver R1200RT
It's true that adding LED brake lighting on an ABS bike can cause system errors. But you can still replace the lens without replacing the bulb-type, even on an ABS bike.
If you want LED enahncement to your taillights, and you have ABS, then you may want to stick with the BMW LED mechanism that attaches behind the license plate.
#429 (in for life)
'06 Silver R1200RT
'06 Silver R1200RT
soggybottom
Clear Taillights
You could also check out http://www.nippynormans.com they L.E.D. taillights and clear lens kits for both ABS and non ABS bikes. So far the only ones I seen with different models for ABS and non ABS bikes.
P Jensen
14 R1200R
Montego Blue
NW VT USA
14 R1200R
Montego Blue
NW VT USA
socalrob
If anyone tries the NippyNormans LED rear turn indicators that also have a single band of red LED's in the yellow LED pod. Seems like it would be nice to have brake lights activate in the turn signal pods.
Is it compatible with ABS? The web sight does not say.
07 1200GSA & 08 Ducati Hypermotard S
& Honda XR400
Past-04 R1150R
& Honda XR400
Past-04 R1150R
