Oil pressure switches - am I just unlucky
R1150RDave
Post by R1150RDave »
Last year I found my left foot was getting covered in oil as was that side of the bike. Fortunately it was just a leaking oil pressure switch.
Now the replacement switch has gone faulty by not lighting up when the main switch is turned on, then somtimes it does, then somtimes it comes on dim.
The new switch is coming FOC, but is this a common fault with this switch?
:shock:
R1150R 2001 Red on Z6s in England. Done 30,000 miles.
DJ Downunder
Post by DJ Downunder »
I've never heard of it before now.
wncbmw
Post by wncbmw »
First I have heard of that also. My left foot got covered in oil from a faulty valve cover gasket! :?
Vann - Lifer No. 295
Boxer
Donating Member #: 2
Post by Boxer »
Never heard of it leaking. Mine went belly-up earlier last month and I had to replace it, but it never leaked oil. I suppose if it wasn't properly sealed when replaced it could leak. The manual says to use a sealant when you screw the new one back in.
jonmaddux
Washer
Post by jonmaddux »
There should be a thin crush washer pre-installed on the replacement oil pressure switch.
If you use any sealant (and you should not need it because of the crush washer), use very little. Use something like Locktite 565. Sealant will affect the grounding path of the switch which will give you a false reading. When there is no path to ground, the light comes on.
R1150RDave
Re: Washer
jonmaddux wrote:There should be a thin crush washer pre-installed on the replacement oil pressure switch.
The switch leaked from the tip where the wire clips on, the base was OK.
KHaynes
Leaking oil pressure switch
Post by KHaynes »
I worked in the motor trade for a number of years and this problem came up frequently. The common source of the leak is where the metal shell clamps onto the plastic body.
You're very unlucky to have 2 failures. I'n not suggesting that this is the case but the switch can be easily damaged by using the incorrect tool to tighten it.
Keith Haynes
R1150RT
Wheelcaps
