Next, connect Twinmax to the throttles and mount the TM onto the tank so I can observe the balance while driving at speed.
At idle the TB are perfect in sync, at any contant speed the TBs are perfect.
What I noticed when I either throttle off or throtthe on the Twinmax swings to 1 or 2 to the left cylinder for about half second. This happens only with a normal progressive twistgrip action, but if I wack open the throttles the twinmax stays put in the middle.
Vacuum is a result of air and fuel, the latter we cant control with fuel injection. If I suspect injectors I would see the
The Twinmax is measuring vacuum, so is there a problem on the left or right and what could the problem be?
