Foggy mask
- Nakigara
Foggy mask
Check out this link.
http://www.kneedraggers.com/details/Res ... 02324.html
I just bought one of these at the local stealership for $19.95. It's made to fit between the foam cheekpads and the helmet lining. They are not made to fit flip up helmets like Schuberth, but if you want to fiddle with it you CAN get it to fit. I tested it in my Schuberth today and it works great! A bit of a pain in the ass to get into place initially, but worth the trouble when it's 20 deg outside!
Dan
Dan
DJ Downunder
I bought a foggy mask too. They work as advertised, but might be a little clostraphobic (SP?) if you swear at the traffic a lot like I do.
At about the same time, I bought a Arai XD Supermotard helmet and eliminated all of my fogging problems. The fron vent is excellent and keeps the fog away except on the worst cold, rainy days. In that case, I opn the visor one small click and the fog is gone.
Get your facts first, and then you can distort them as much as you please.
Mark Twain
Mark Twain
mtwillyman
Foggy and Fog City
I have Shoei XR1000.
I swear by the Foggy Respro and the Fog City - I
NEVER
get mist.
And at the moment the temperature here is just above freezing.
The only sting in the tail with Foggy is having to readjust it after you take it out to wash it. It really buggers me.
Foggy is a keeper but....
I have the mask in two of my helmets. Absolutely not foggy issues and I was a long time user of the fogshield product. My only two knocks on the product are:
1) You have to always remember to hold it while taking your lid off or the metal nose piece can scratch you up a bit.
2) If you are stuck in the heat and NOT moving, it will get hot.
Those are my two cents!
I've done the anti-fog stuff in the past and like Brian said, it doesn't last. It seemed like the colder it got, the quicker it would stop working. Days in the low 20's will have you re-applying it daily, but it does work. Then I got the Fog-City fog shield. Great product BUT.......It is very soft plastic and is easily scratched from cleaning. I would say buy a new one every fall/winter and remove it in the spring. The other bad part of the Fog-City shield is it slightly distorts your view, meaning it makes things a little harder to see at night and in the rain, but it's much better than fog.
I'm about due for a new helmet and supposedly the Scorpion helmets have some kind of anti fog shield built in. A co-worker has one and swears that it doesn't fog, but he doesn't ride in as cold weather as me either. They do advertise it's non-fogging capabilities.
Member 293 (I think)
'17 Triumph Tiger 1200 XRX
I have one, and it will fog, given the right conditions. It may be more resistant than others, but it fogs nonetheless. Hence, my purchase of a Respro.R4R&R wrote: I'm about due for a new helmet and supposedly the Scorpion helmets have some kind of anti fog shield built in. A co-worker has one and swears that it doesn't fog, but he doesn't ride in as cold weather as me either. They do advertise it's non-fogging capabilities.
