It's not difficult at all mate...
Pull the plug cable cover off and there's two bolts each....back those all the way until they come loose (don't try and pull them out yet...there is a grommet on them), and then gently wiggle the cover until it comes off. Should be stuck on pretty good because of the heat.
You want to then clean them up really good and get all the oil/dirt off of them and go ahead and remove the retaining screws/bolts at the same time. You also want to go to your dealer as there is a little grommet gasket thing that slips over the spark plug and you should not reuse the one that's there now. They're like a buck each. Get that PJ1 - Satin Black case paint from your local dealer while your there.
Then it's just a matter of lightly sanding them and painting. The only real beeatch is the in-between the fins area.
Piece o'cake! Have fun!
EDIT: PS.....you need to be careful when you remove the spark plug cable. There is a little clip there that you squeeze together to remove. I was told that if you break the clip, the whole harness has to be replaced and it's quite expensive!!
drevil wrote:i actually scraped mine up a little. how hard to pull them off and paint?
