Tank Protection
marecycling
Tank Protection
Weather here in New England has finally broken, and am riding all over on my"new to me" 2002 R1150. I have a minor problem I am looking for help to remedy. When I am riding with my favorite leather jacket on, the position I am most comfortable in causes the edge of my leather, where zipper is located, to rub against my tank at the base where it meets the seat. It is scratching the paint, and before I rub out the scratches, I would like to have a remedy in mind so I only have to buff out the scratches once. Could I get some suggestions.
The "good things" that come to those who wait, are just the "leftovers" from those who didn't!
Just go to any motorcycle shop and they should have a few to choose from.
I got mine from an Autobarn auto shop...it's a thin gel type pad about 6"x4" (maybe a little bigger) that sticks without glue..it's designed to stick on your car dash and you can sit your mobile phone on it and it won't slide around...cost about $5...and its texture matches the seat.
I could post a pic if you like....you could even make yourself one using that contact plastic that you use for books.
Those things are called tank pads here in Old England!
Just clean the tank with some alcohol based cleaner and gently heat both the tank and the pad with hair dryer before applying.
Some tank pads come as kit with little knee pads, for extra grip when cornering.
Also - get yourself BagLux tank cover.
Cheers
Cheers
Got mine at good old walmart just bumming around the auto dept. These things are cool!! Gotta get a couple more for the car and now maybe one for the bike!!!DJ Downunder wrote:Just go to any motorcycle shop and they should have a few to choose from.
Craig
Life is too short to use cheap toilet paper
Member #457
95 R1100R Red
Member #457
95 R1100R Red
Me, being of the larger belly variety, also suffered from this tank scratching.
I got the CSS Tank protector set from BMW Santa Cruz, not sure where to get them internationally.
http://209.61.235.222/Merchant2/merchan ... t_Count=28
Nice look, $30 USD, the middle one in the picture goes where the tank meets your seat.
marecycling,
If you want durable, removable, invisible, inexpensive protection for all the tanks body contact points . . . like where your knees can rub, then get this one:
http://www.thetankslapper.com/
Everything they say about it on that website is true. I've had it in place on my bike for about 3 years and it's still protecting. An R1150R three Piece Tank Protection Kit is $15.95 plus $3.95 S&H. It's a great, yet simple, quality product and the owner/seller even followed up with a brief satisfaction inquiry E-Mail.
king biscuit
Good Tank Protection
I put one of these http://www.mag-knight.com/ on my R. Worked great, didn't cost a bunch and could be easily removed if I decided that I wanted something different.
Dan
Dan
King Biscuit
Member # 456
Member # 456
mechanic savant
