Checking oil revisted
dwayne
Post by dwayne »
Okay, I am starting to lose control here. Every night when I shut the bike off, I center stand it, then 10 ~ 12 hours later I come back check the oil, and guess what, nothing in the resvoir. It has been like this for two morning now. So this morning I check the oil on the side stand and there is oil up to just past half way, but when its on the center stand there is none to be seen. I put in about 3 oz as soon as I got home last night then went for a quick ride, checked the oil agan on the center stand, no oil. THis morming I put in 1 more oz. On this mornings ride, oil was coming out of the oil filler cap. I am at witts end with this. Its either registering empty or blowing oil cause its over filled!!!!
'05 R 1150 R Dark Ferro, with blacked out motor Member # 507
MikeCam
Centurion Moderator!
Donating Member #: 100
Well
Post by MikeCam »
You're doing it wrong.
chris
Post by chris »
Remember centre stand, gear off, side stand, kettle on, centre stand, check oil. The coolers don't drain if you centre stand it so it looks empty. Fill it up as you describe, ride it, the coolers flush and you now have too much and it comes out the plug!
Chris
2011 G650GS
Photos
MikeCam
Well2
Post by MikeCam »
Dwayne,
I went searching for the answer from previous tech posts to find the one that best describes the Roadster's quirky oil level performances...
Meanwhile, Chris hit the nail faster....
Best of luck.
Cam
LonestaRR
Post by LonestaRR »
Arbreacames
Re: Checking oil revisted
Post by Arbreacames »
dwayne wrote:On this mornings ride, oil was coming out of the oil filler cap. I am at witts end with this.
By any chance, did you find that cap by the side of the road in Texas? :-)
I think that your procedure to check the oil is OK. It is your diagnosis about the overfilling that is not. Overflow oil goes to the bottom of the airbox, which you can check by removing the cap underneath the box. If oil comes out of the filler cap it is because there is something wrong with the cap.
Carlos D.
As said - oil should be checked when warm/hot - not when cold.
rockster.ch
Post by rockster.ch »
I centre-stand it and if I remember I want to check oil, come back in 10 minutes.
Cunningly, it's bang on the button and has been for 1000km since service ;)
MikeCam
Final Word???
Post by MikeCam »
Here is the original, Patrick approved, Darth tested, Dean vindicated, and Cyclerob certified method circa June 2002:
Warm from ride of at least 15-20 miles. Engine off via key only. Sidestand exactly 7 minutes. Center stand on level ground. Wait 1-5 more minutes. Read level. Optimum is center of sight glass. Acceptable is anywhere visible in window.
Of course, that is for a 2002 R1150R (ABS or non) single spark, 1st year of U.S. release. Euro measurements differ accordingly. Your mileage may vary. To each his own. One man's ....you get the drift.
Boxer
Donating Member #: 2
Post by Boxer »
I inadvertently turned off the engine with the kill switch once and my oil level immediately dropped to below the circle.
I then had to push start it so the air in my battery would come up to proper pressure.
MikeCam
Ha
Post by MikeCam »
Wicked!
MikeCam
Post by MikeCam »
Previous was #600 post. Appropriate descriptive, no?
Gordium7
Donating Member #: 566
Kill switch?
Post by Gordium7 »
OK, you have my curiousity going.
How does using the kill switch effect oil level?
Inquiring minds want to know....
2005 R1150R -- Granite Grey Metallic
Lifetime Member #566
MikeCam
Bait?
Post by MikeCam »
Phil,
What did you use? A spinner or a crank?
Boxer
Post by Boxer »
Crank. I can't keep an eye on those spinners with my bi-focals.
LonestaRR
Re: Kill switch?
Post by LonestaRR »
Gordium7 wrote:OK, you have my curiousity going.
You should go back and read some more of Boxer's posts throughout the forum. It will enlighten you.
k
pjpockets
oil level
Post by pjpockets »
As mentioned before, put the bike on side stand for a few minutes after a ride. this drains oil from the coolers and lines. Put bike on center stand for a few more minutes, the check the glass. In the middle is supposed to be perfect. I put in a touch more as mine is still consuming. Its all very simple. DONT PANIC!!!!!!!!!
