r1100r fork travel question
sonny
Post by sonny »
hello.. i'm a newbie to the R1100R... my question is: when my bike is on the side or center stand, the forks are stretched out.. however, when i take it off the stands, it seems to bottom out. when i put on my front brakes and rock the bile back and forth, it seems there is hardly any travel at all before it bottoms out .... is that normal ?
thanks for any responses...
Sonny
Ride Safe !
Motorrad
Post by Motorrad »
I wouldn't be concerned about the fork shock extension, because the suspension for the bike is provided by the tele-lever strut (front). However, the travel should be approx 4 1/2 inches.
Steve
Yellow-Jacket
sonny
front suspension travel
Post by sonny »
so when you put the brakes on, and pump the front forks... they should go down 4 or so inches and bounce back up ? cos mine only goes down about an inch and hardly bounces back up at all.
i'm so confused .. :?
Ride Safe !
Motorrad
Post by Motorrad »
The TOTAL travel is approx 4 1/2 inches, the weight of the bike will eat some of that distance up, plus your own weight. I get roughly a 1 1/2 inch deflection when I rock my bike forward. I weigh about 175 lbs and could not generate enough force to fully compress (bottom-out) my suspension. Are you sure it's bottoming out?
Steve
Yellow-Jacket
sonny
oh ..
Post by sonny »
from what you are saying... out of 4.5 inches, the bike takes up 3inches,.. and there's 1.5 inches left. that's what it seems like on my bike too. so i guess its normal after all. i thought something was worn out..
btw... what's in the fork anyways ?
sonny
Ride Safe !
Motorrad
Post by Motorrad »
I'm sorry, maybe I'm not explaining it correctly. You SHOULD'NT have only 1 1/2 inches to go before you bottom out. If that was the case, every time you hit a bump your teeth would fall out. I was saying that I could only force my suspension down about 1 1/2 inches, but it certainly WASN'T bottoming out.
Steve
Yellow-Jacket
Motorrad
Post by Motorrad »
Also...
The fork shock is basically a tube within a sliding tube, and although it does have oil in it, according to the engineers, it doesn’t provide much suspension.
Steve
Yellow-Jacket
single650
Post by single650 »
The front wishbone setup seperates braking fom suspension on the oilheads. They are designed NOT to dive under braking, therefore putting the brake on and rocking the bike forward will have little effect.
To check suspension travel just push down on the bars
'03 R1150R Rockster
'94 K75s
leno
Post by leno »
Welcome to the world of BMW where things happen differantly. Those forks are not real forks but just tubes to connect the handle bars to the front wheel and to stop people freaking out. You will find that the front of the bike tracks the road better particully on poorer quality roads.
sonny
fork travel qurstion
Post by sonny »
ok... sorry to be so persistent .. maybe i should rephrase my question ...when my bike is on the center stand... the forks show 5.25 inches of chrome (distance between the bottom of the black plastic fork cap and the top of the boot.).. when the bike is sitting straight on two wheels, and with me sitting on it.. there is 3.5 inches of chrome. would this be normal ????
thanks again ...
Sonny
Ride Safe !
seanwu
Post by seanwu »
By right its should be shorten but I don't know by how much. if you really want to test to see if the front fork will dive, when you travel at around 20km/hr, try using the rear brake only; this way the front fork dive more obviously then its using front brake. You can judge if the fork had max out or not.
The reason for using rear brake its because the front fork is using telelevel therefore, it wouldn't dive down no matter how hard you apply front brake, thats a good thing about BMW bikes.
Go where there is no path but leave a trail.
single650
Post by single650 »
Sonny, That seems pretty normal to me.
I was watching mine on the road (not a very good idea) and it moves about 1 to 1 1/2 inches over bumps and stuff.
Its not as much as normal sprung forks because of the BMW design
'03 R1150R Rockster
'94 K75s
sonny
thanks for your responses.!
Post by sonny »
good to know that my bike's front end is 'normal'....thanks for all your help...
sonny
Ride Safe !
