R1200R pics
Here it is in French:
La présentation commerciale de la nouvelle R 1200 R dans vos show-rooms aura lieu àpartir du jeudi 14 septembre 2006.
La R 1200 R est proposée au prix client de 12 000 € TTC.
Options et prix client en € TTC :
Echappement Chromé 100 €
ESA (Suspension pilotée) 680 €
Poignées chauffantes 205 €
Témoin de pression des pneumatiques 210 € (date de disponibilité àconfirmer)
Ordinateur de bord (sans témoin huile) 150 € (date de disponibilité àconfirmer)
Saute Vent 170€
Clignotants blancs 35 €
Système d'alarme antivol 190 €
ABS intégral 1080€
Béquille centrale 110 €
ASC (seulement avec option ABS) 290 €
Supports Valises 85 €
Selle Basse Noire 770mm 0 €
Selle haute 830mm 0 €
Saute Vent 170€
ABS intégral 1080€
Here are the specs I posted on another thread (Translated from French).
Someone on forumactif.com posted the following (in french)
http://r1150r.forumactif.com/ftopic2485-0-asc-60.htm
These seems to come from a spec sheet:
- 109 hp
- Weight: 198kg (436.5lbs)
- Optional ABS braking may be associated with Automatic Stability Control (ASC) inspired from cars, a system that prevents the rear wheel from spinning while accelerating on slippery surface. As with ABS, a computer compare the wheel speed and as needed shuts off the ignition complemented with shutting off the fuel injection.
- RDC = Tyre Pressure Control
- The on-board computer displays: speed, avg fuel consumption, range, outside temperature, risk of icing on the road, oil temperature, and gear.
Coming to a show room on Thursday 14th september 2006
The usual accessories.
Options:
Price in US$ converted from 1Euro @ $1.29
- Chromed muffler US$129
- Heated grips $265
- Gauge of tire pressure $271
- Onboard computer w/o oil temp. display $194
- Windscreen $220
- Clear lens turn signals $45
- Anti-theft alarm system $245
- Integral ABS $1394
- ASC (with ABS only) $374
- Centerstand $142
- Case Rack $110
No sir, I don't like it!!
Makes me think of a Honda CB, and that can't be good can it...
This 1200R looks like the 1150's baby brother, to be placed somewhere between the new 800's. That might be because it looks cheap
Ofcourse I'm not talking about performance, may very well be that it's more powerfull, But I for one don't care...
Just by looking at the future generation Roadsters I can say that I'm going to like my rockster more then ever before
R1150R Rockster
jon pierce
- yjleesvrr
- Member
- Location: Blacksburg and Haymarket, VA/Basking Ridge, NJ
I think BMW Motorrad has always been a little off center (sorry, I have to spell like an American!). I like the new Roadster. It's not stunning, but it's about as much as I had hoped for. I'm test riding one as soon as my dealer has one.
Member #93, June 2002
'14 BMW R1200RT "Wethead"
'77 BMW R100/7 "Airhead"
bubbleman21
r bike
i'm just glad bmw removed the beak. i never got the point of it. now, how much more are they going to increase the engine size before the heads need a support brace?
If it is like the other 1200 series bikes, the battery should be under the seat.
I think the purpose of the beak was to break up the distance from the telever and the headlight. lower head light means no beak.
The more I look at the 1200R the more I like it.
Jeff (lifer #289)
'17 F800GSA
'17 F800GSA
For the love of the metal hammering gods and pavement sweeping demons, did they finally put self-cancelling signals on that thing? In a day when they can squeeze the last fraction of hosepower and torque from a motor, install a catalyst system to save the environment, and reduce the weight 50 pounds, you would think they could add a signal cancelling system that is as modern (like only 30 years modern!) as it's competitors machines. I'd tolerate the plastic fluid reservoirs for self-cancelling signals. I know BMW prides itself on being different, but let's get real. Okay, I feel better now.
cricman
cricman
eric
You got a good point there. If the bloody thing can tell ya what the tYre pressure is on the fly, why not turn off the blinkers???cricman wrote:For the love of the metal hammering gods and pavement sweeping demons, did they finally put self-cancelling signals on that thing? In a day when they can squeeze the last fraction of hosepower and torque from a motor, install a catalyst system to save the environment, and reduce the weight 50 pounds, you would think they could add a signal cancelling system that is as modern (like only 30 years modern!) as it's competitors machines. I'd tolerate the plastic fluid reservoirs for self-cancelling signals. I know BMW prides itself on being different, but let's get real. Okay, I feel better now.
cricman
Tho i gotta say I was able to take a spin on a 1200C recently and on that bike, there was a nice "click" when you squeeze the cancel button. Is that the same on the 1150R's??? I really liked after about three signals and missed it like hell going back to the 1100!! Perfect, i;m sure not but still leaps and bounds above what I have to live with.
Craig
Life is too short to use cheap toilet paper
Member #457
95 R1100R Red
Member #457
95 R1100R Red
- elmandarino
Errm not sure. Love the idea of reduced weight and a bit of extra power. However, I think Iwould have to invest in a fender extenda pretty smartish. More worryingly I had a steering damper on my old R1100R and it was one of the reasons I got rid of it. I hated the slow speed steering.
2001 Black BMW R1150R
And what about the beak-less Rocksters? They don't need that air deflected to the oil coolers? I thin kit was for looks.Acpantera wrote:The beak was suposed to direct air to the oil coolers..........function over form.........thats what BMW is all about.
Member 293 (I think)
'17 Triumph Tiger 1200 XRX
