Hello, to you all.
Lately, my bike has begun to exhibit a strange idiosyncracy--it will occasionally refuse to go into third gear. More often than not, it does this when the bike is nice and warmed up. For instance, I'll stop to get gas after being on the freeway and it will happen when I'm shifting gears trying to re-enter traffic from the on ramp. It's a real surprise and pain in the butt when it happens.
Has anyone ever experienced this?
Can't Get Into Third
- The Velvet Monkey
2004 50R a.k.a. "Hiedi"
No!!! Bad monkey!!
No!!! Bad monkey!!
DJ Downunder
- The Velvet Monkey
Thanks for your responses.
I've got almost 18k on the clock. I replaced the fluid at 12k, but I'd experienced this problem before then, although it seems to happen more frequently now. I've also never had it happen when the bike's cold.
I'd like to take it to the dealer but as you hinted it happens only sporadically and I don't think I'll necessarily be able to reproduce the effect.
My warranty is up this February, so I guess I should get the problem on the record at least.
No!!! Bad monkey!!
No!!! Bad monkey!!
I've been having the same issue. I find that it tends to happen within the first 5-10 minutes of my ride. It's very intermittent, but when it does happen it takes me a couple of attempts at the shift lever to get it into gear. I'm planning on changing the fluids in mine this weekend, to see if that helps.
Steve
Yellow-Jacket
Yellow-Jacket
