Whats with the Shaking
MesquiteDave
Post by MesquiteDave »
I have a 03 beakster with around 11k on it so far. I’ve noticed a vibration that’s constant. It’s a high speed vibration though not very strong, makes the left mirror really vibrate makes it hard to use and after about 20 min's of riding my right hand goes numb (have to shake it out and get the blood flowing again). Not sure if its just the vibration you get with a 2 cylinder or if its needing some work.
any ideas guys?
Lean Angle
Post by Lean Angle »
What may help is proper valve adjustment and throttle body synchronizing. If you're a wrenchie, there are some very simple and informative info on the advrider site, wisdom section. Happy hunting :)
ProductUser
Post by ProductUser »
There will always be some sort of vibration; it's the nature of the boxer engine. Proper valve and TB adjustments can reduce it, but it will not go away. My vibration is at its worst around 4k rpms, so I just work around it. Others have bought a foam/neoprene grip covers that seem to absorb some of the vibration. Another problem may be that you're gripping too tight or that your riding posture is putting too much pressure on your hands.
Others will chime in with their solutions, but this what I've read on this topic.
ProductUser
jm1515
Triple Lifer
Re: Whats with the Shaking
Post by jm1515 »
MesquiteDave wrote:I have a 03 beakster with around 11k on it so far. I’ve noticed a vibration that’s constant. It’s a high speed vibration though not very strong, makes the left mirror really vibrate makes it hard to use and after about 20 min's of riding my right hand goes numb (have to shake it out and get the blood flowing again). Not sure if its just the vibration you get with a 2 cylinder or if its needing some work.
any ideas guys?
The left mirror will always vibe...TADT from what I'm told.
I don't think the Boxer will ever be as smooth as some other engines...just the nature of the beast. But I would say that if you are getting numbness in the hands, you should check valve/TB specs and see if that helps. Then check to see that you are not using a death grip on the bars....
In the ~15000mi I've done in the last year and change, I have never had numbness...but occasionally do have to 'shake out' the throttle hand on longer rides just to give it a rest....
j magda
TripleLifer Member 454
Deep in the OH wasteland...
MesquiteDave
Thanks for the replys guys, while I might not be the most handy guy around (you can check with my wife on that one :oops: ) I can generaly get around a peice of machiney with a good set of directions. If you guys might have a link to where the valve adjustment and throttle body synchronizing how to's that would be great.
Lean Angle
ProductUser
MesquiteDave wrote:Thanks for the replys guys, while I might now the most handy guy around (you can check with my wife on that one :oops: ) I can generaly get around a peice of machiney with a good set of directions. If you guys might have a link to where the valve adjustment and throttle body synchronizing how to's that would be great.
Just in case you didn't know....
Please be careuful not to run the engine without a couple of box fans, one blowing on each cylindar, to avoid overheating the engine.
ProductUser
NHighCotton
Post by NHighCotton »
Had the same vibration recently with my new (bought 6/06) 2003 1150R. When I bought it had 10K on it and a fresh tuneup. 13K now so I figured the valves were Ok and they didn't sound OOA.
Also recently purchased a Twinmax and gave it a try today, apparently the mechanic before me didn't tighted down the cable adjuster at the carb on one side, as it was loose.
A few turns and I'm back to purring again :D
That Twinmax is a cool tool :smt023
2003 R1150R (SOLD 8/07)
(9/07) 05 FJR1300
1986 R80RT
1974 R90s antique (on the road again)
Lean Angle
Yup, the TwinMax is the bomb, especially for on-road testing :D
dcameron
Post by dcameron »
Hey, it's a double thumper. I like the feel while at a stoplight. All bike, all thrills, no frills.
Evil beware, we have waffles.
'03 r1150 - the beast
'11 r1200 - Hooligan
#564
geothepencil
Post by geothepencil »
I think the vibration from an R/R is much less likely to cause hand numbness than the buzz of a K engine.
geo
BoiseBeemer
Post by BoiseBeemer »
geothepencil wrote:I think the vibration from an R/R is much less likely to cause hand numbness than the buzz of a K engine.
geo
Absolutely. Before purchasing the Roadster, I put a couple hundred K on big Suzuki fours. Wonderful bikes, but after a day on the road, my right hand was always a bad combination of tingling and numb. I'll take the thudding of a big twin any day over that high-pitched vibration of a four-cylinder.
Bruce Jones
2004 Silver Roadster
2004 Copper Rockster
1953 Platinum spouse
jas
Post by jas »
Squeeze the heck out of your left grip and the vibrating / quivering in the mirror will subside. Now, rest your right had on the throttle and the right mirror will vibrate like hell. Could be the valves, could be a death grip.
2004 Roc.
SLEDGE
Post by SLEDGE »
I vote Valve adjustment and throttle body scynch. My r1100r purrs like a kitten.
R.D
sjbmw
Moderator
Donating Member #: 263
Post by sjbmw »
geo
right on there. After 3 asian 4's, getting my right hand back has been a blessing. went riding with a HD guy all day who complained of hand numbess.
"What's that?" :)
