Engine rattle 2.5 to 3.5k revs
Rode my bike last week without ear plugs and heard a slight rattle from the engine in the 2.5 to 3.5k rev range. Not audible with my plugs in as it is quite high pitched. Any ideas?
- NHighCotton
I think you mean 'pinging' or more correctly, 'pinking'. That's a fuel quality/octane issue, and is further affected by load, altitude, uphill running, pillion/baggage weight and so on.
If it's an early 1150, it may also be the left cam chain tensioner. BMW have two mod versions, and I'm about to switch mine over to quieten down some startup and hot idle rattles from the left cam chain.
BUT - at the rpm you are stating, it's unlikely to be the tensioner and probably not pinging unless it's only under load.
- cworley5150
- Location: Princeton (not NJ but in the other armpit) WV
Fooking Aye! I often ride with "plugs" or ear buds with the mp3 player. When I go without them, I think "Oh poo", the Rock is falling apart! Then I remind myself of the various "mechanical music" the boxer makes. Everything should be fine. Ride on my friend.plum wrote:keep the ear plugs in![]()
Might be normal....I hate riding without ear plugs....I alwasy think my bikes are falling apart.
No matter where you go, there you are.
Boxers Rule! Umm. . . the bikes, not the underwear.
Wow ! Thanks for the quick responses.
I don't think it is 'pinking' I had an old car that did that and know the sound. This sound is definitely metal on metal.
Does seem to come from the left side, so may be the tensioner. I had exactly the same thing on my old CBR600.
I have a full BMW service history and it is due and annual service at the end of the month. Out of warranty though (a 2003 model and we get 2yr warranties only in the UK).
I have found a link to a post which has nice pictures showing how to replace the tensioner - I will see what the dealer has to say and will probably do it myself.
cheers
cheers
Ebuyergum
I couldn't leave the post mentioning that one of our ilustrious members and assidual poster on this site, BOXER, has a very good description along with photographs of what the process entails.
Basically if you have a set of metric tools and have some basic mechancal knowhow the repair is very much doable.
