2005 Granite Grey ABS, purchased May 2005. Total of 500 miles on odometer.
Dealer did 600 mi service before pickup.
Since this bike was a demo, I assume that the "hard" break-in approach was applied.
I mostly ride reasonably, except when I don't. I make of point of doing hard accelerations periodically when I can can get away with it, or perhaps just for fun. I don't think I have been over 90 mph however (yet!).
So far this summer, I have been commuting to work (30 mi RT) about 75% of the time, even though we've had a wet summer (for Colorado). I have only gotten in one or two long day trips a month so far.
At 2000 mi oil was at lower quarter of the sight glass, so was topped off (~ 8-10 oz).
Currently nearing on 3500 mi, and would be ready for another oil tweak (bit below half), but I am going to change the oil and filter this weekend.
Oil usage seems to be decreasing already, a 33% decrease in consumption rate since first 1500 mi datapoint.
Only widgets installed are SignalMinder and headlight modulator. Made custom tiedown loops for the normal system case attach points and use a semi-rigid tailbag (i.e. a AXIO tankbag) on the rear seat during commuting and daytrips. Have a the Verholen / Hein Gericke mini-tankbag that sits on the fuel filler area when needed.
When I do the oil this weekend, I will check and adjust the TB sync if needed. Idle is a bit low (950-1000) once warmed up, so I will correct this during TB adjustment..
No problems whatsoever.
Nothing quite like cruising up into the Rockies on this machine. I am soooo spoiled now.
I really love this bike.
