hello beemers
newbie with a 2002 bumblebee R1550R
when i got the bike it came with a TENDER PLUS batterie charger
the guy that sold it to me had just bought a new gel batterie
and never used it
does anybody has one ?do they work well? and is there a procedure to using it ?
it has attachement for the side plugs on the bike and i have the plug
comments please and thank you .
my englich might be a little rough being a french guy in New brunswick
ok i might as well keep going
went for a cruse today .....a real treat for me here in the maritimes in november and a forcast of 18 plus for tomorrow....yummy
wow i had fun and push the bike harder then ever i think it liked it as much as i,
well dropped at the dealer to see that new 1200
a beauty they wanted 21,000 canadien dollars with olin ass end
and ABS that's a lot of coins...but it's pretty
i'm working on a BMW patch to wear when i'm not riding
i'll let you know how it comes out
thanks all
Pierre
tender plus
tender plus
why is there straight roads out there?
- Parkblu
- Location: SE Florida, sometimes Munich, sometimes Raleigh NC
Salut Pierre, et bienvenue içi!
I just bought a Battery Tender Plus for a gel battery, and it seems to works fine. I did some research (a lot here on this board) and though the Tender Plus is not totally ideal for the BMW exide battery, it should work great.
It sounds like your bike has the accessory socket (on the left side, looks a bit like a cigarette lighter plug with a spring-loaded lid) ? If so, you can use (or get) the adapter that will allow you to connect the battery tender to that plug. On 1150Rs, the battery is hidden under the tank, so not ideal to reach.
Battery Tender manual says to plug the charger into the bike socket first and then connect the charger to a wall outlet.
In regards to the lights of the charger I have to check again, but I believe red blinking means no battery connected, and green blinking means trickle charging. Red and green solid I'll have to look up.
Btw, '04s and later came with a gel battery as OEM, older ones don't.
Ride safe, welcome to an excellent board, and have fun!
-tobias.
-tobias.
