how many miles on a full tank?
Given that our R's dont hve a gas gague, i use my trip meter to figure out when to get gas. It is still unnerving to see the gas light illuminate at 130 mile when I have an idea that I should be able to cover about 200 ...
what are your nubmers like??
colinpollock
I also use my trip meter as a "mock" fuel gauge. The furthest I've gone on a tank is about 185 miles. My light was on at around 140 miles and I stopped at the first station I could find. I was certain I running on fumes. In hindsight, and after checking my fuel consumption (51 mpg, solo on the highway and with no cases), I could've gone another 25 miles or so no problem.
Colin
- 2004 Ferro Blue R1150R
Commuting to work and home, I get about 145 miles before the light comes on. On the weekends on spirited rides, I usually get about 170 miles on a tank. The most I have ever gotten on a tank is 200 before the light came on. I think a lot has to do with the style of riding being done and how much time you spend at the pump. The time I got 200, was on a road trip where if you ran out of gas on the way to the next way point, there were no stations to be had. So at the pumps at each stop, we took our time and made sure to fill up all the way into the neck. If you just fill into the neck and hang the pump up, by the time you close the tank, the level will be way down and you can get another half gallon in if on the center stand.
My light goes on somewhere between 180-210 Km for everyday riding (home-work-home) and have gone 250-260 Km max (don't want to risk running out.
I do about 13-15 Km/L everyday, have done 22 Km/L on a Highway trip.
BMW Riders Club of Greece
http://www.bmwriders.gr
Paul Mihalka
Paul Mihalka
- yjleesvrr
- Location: Blacksburg and Haymarket, VA/Basking Ridge, NJ
My warning light comes on between 185 and 202 miles on a full tank. The variation comes from the direction and speed of the wind, not to mention what kind of load I'm carrying while touring.
I've gone as far as 230 miles on a full tank, but I was running out of gas to the point the engine was sputtering. I had to shake the bike back and forth to get gas from the various nooks & crannies of the tank down to the bottom where they could be pumped to the engine. I barely made it to a gas station in time to avoid being stranded.
I cruise at 70 - 80 mph on the highway.
Member #93, June 2002
'14 BMW R1200RT "Wethead"
'77 BMW R100/7 "Airhead"
ProductUser
fallingpines
