I had put it off for the longest time, having read posts about it more than a few times earlier. Finally tonight I thought I would venture to the garage and check, even though I haven't experienced a problem with my 2004 (silver) so far.
Sure enough when I checked the cable ties securing the wiring harness by the fork in front of the gas tank, they were snapped supertight and I could see by turning the handlebars how much stress was being played upon this area---crimping them with every turn. I removed the first, foremost tie and underneath, the harness cover had been worn through. As far as I can tell the cable tie had not yet cut into the wires but it was just a matter of time. I think...I hope...I've avoided a potential problem here. I've got some long trips coming up and Murphy's Law being what it is, sure enough would have manifested itself once I got far away from home.
So, please do yourself a favor. This over-tightened cable-tie issue has been commented on time and again regarding issues from indicator lights not working to starter switch problems to even engines cutting out in turns. If you haven't already done so, check your ties and ride...safer.
Happy Holidays to all......
