External Fuel Filter ?
Ozhirsty
Post by Ozhirsty »
Tank is off. Replaced Air Filter, connected Battery Tender charging line,
removed and replaced all cable ties, (all to tight)
While tank is off, want to replace fuel filter.
Question. See from recent post that plate nuts easy to break off. Thinking of also replacing internal filter, but replacing same filter externally in line above disconect valve. Is same (internal type) filter okay for external application in fuel line above disconect valve?
Previous post mentioned doing this, but looking for a post on actual job if there is one.
Any info appreciated..
Alan
'04 silver r
28,000 miles
taosports
Post by taosports »
Alan -
Here is a link for the mod to a 1150 RT - should be identical to the R
http://www.ibmwr.org/r-tech/oilheads/ex ... ndex.shtml
Let us know how it goes if you attempt it!
socalrob
Post by socalrob »
One benefit to having the filter in the tank is it can't leak :D
07 1200GSA & 08 Ducati Hypermotard S
& Honda XR400
Past-04 R1150R
awagnon
Post by awagnon »
I believe the fuel filter is after the pump which builds enough pressure to blow off hoses and even spit filters if the line gets kinked. If that happens, and it has happened to me, I'd rather it be inside the tank. This can be dangerous.
Al
Ogden, Utah
2002 R1150RT
2004 R1150R (sold) (sigh...)
2004 R 1150GS
challey
Donating Member #: 365
Post by challey »
Has anyone who's done the external fuel filter mod had the same experience as awagnon? Is it common and that's why moving the filter outside the tank is not a more popular modification?
'03 R1150R
Life member 365
Errabundi Saepe, Semper Certi
Ozhirsty
Post by Ozhirsty »
Michael:
Thanks for the link for fitting the external filter.
Will leave this mod till out of warranty.
Cant see pressure being a problem with filter/lines. If lines are rated to 50psi then actual pressure would be less than half that, safety factor etc.
Mentioned also that if filter fails (splits) in tank not a problem. I think this would prevent fuel delivery, could be wrong here.
Thanks all for great imput,
Alan
r1150r
28000 mls.
awagnon
Post by awagnon »
In my case, the quick disconnect on the fuel line from the tank was not fully seated and therefore closed. This "dead headed" the fuel pump blowing the hose off the filter inside the tank. Of course, the bike wouldn't run, but also didn't get fuel all over. The BMW mechanic said he had seen ends blown off filters and filters split. I suspect BMW put the fuel pump and filter in the tank for a reason. As infrequently as it needs changing, I'd just leave it where it is.
Al
Ogden, Utah
2002 R1150RT
2004 R 1150GS
