Dented tanks
Dented tanks
Post by 1150929 »
Got a call from my wife about my kids accidentally tipping my sports bike onto my R. Ran home only to find no damage to the R, but 2 dents to my sport bike’s tank and a minor scratch on the fairing. :( Seems like it landed on the BMW’s right motor head.
Can tank dents be removed? Any experience here?
Oh, and if I kill my kids, could I plead insanity?
Rui
'03 R1150R silver w/abs,black motor,bags,backrest,givi
'00 CBR929RR
'08 Road King Classic
baltm604
Post by baltm604 »
Does anyone have experience with these guys. they will supposedly do all the bodywork on a naked bike starting at about $600. this seems reasonable
http://www.cyclefinish.net/motorcycle/t ... epair.html
CARTEEUSMC
Post by CARTEEUSMC »
YES ON THE INSANITY PLEA
Clint Cartee
Ian
Post by Ian »
CARTEEUSMC wrote:YES ON THE INSANITY PLEA
No Judge would ever convict
Ian
lowrent
Dented tank
Post by lowrent »
Hi,
Yes I had a dent in my gas tank on my 03 R1150R- size of a small apple.
they pulled/popped the dent out and you would not even know where it happened.
otherwise check ebay and maybe you can find a good deal on a "gently" used tank & replace
good luck
reyb
Post by reyb »
If the dents don't have creases or no real paint damage, then I would try a paintless-dent-repair type shop, which it seems that lowrent had done. Approximate cost is something like $60 a dent, but IMO it's a lot better than bondo and paint.
1150929
Post by 1150929 »
Thanks guys...I'll try some paintless repair shops this week.
Rui
'00 CBR929RR
bransan
Post by bransan »
Had My r65 tank repaired at the local body shop,( the good one in town), $300 with fresh paint and NO! bondo. Of course that was a few years ago, might be a little higher, but should'nt be $600.
Keep Your Stick On the Ice.
Listen to Me at kaxe.org
cnord
Re: Dented tanks
Post by cnord »
I removed a bunch of tank dents from a Honda (CB550K 76') that I had years ago.; back in the days when I had lots of time.
Anyway, I removed (washed!!) all the fuel from the tank and attached the tank to an air compressor via the fuel drain. Pressurized the tank to about 15lb and used a large rose bud (torch) to carefully heat the dents/dumples. Once the dents were out I peened any high spots,used a little plastic body filler, sanded, sprayed with primer, sanded, shot with color. It turned out great. It was nice to work on a heavy steel tank.
C -
2004 r 1150 r
