Actually there have been well documented cases of significant axial misalignment in some of the early ( approx. 20,000 miles ) failures. Of interest, if not corrected, these splines went on to fail again, which suggests, but doesn't prove, axial misalignment probably contributes to some of the early failures. There was a very nice write up in On The Level on the engineering aspects of the spline failure with some of the cause related to the fact the transmission input shaft splines only engage about 2/3 rds of the clutch splines which places excess stress and wear on the splines if there is any misalignment. One report on the metallurgy suggested less than optimal hardness of the splines. That's the data I know about. The incidence of spline failure should be close to zero and it clearly isn't.Greybeard wrote:I want facts.
There is still no data showing that aggressive lubrication of the splines prevents failure. I suspect it just delays it on bikes destined to fail.
