Good luck.
new bike, hesitant to start
I bought my R1150R in September of 2001. Since the day of purchase my bike never started on the first try from “COLDâ€Â. I did complain to the dealer, but was unsuccessful. After 600 miles service, I was soooooo impressed……, that I never let anybody touch my bike again. I did all the maintenance my self, by the book, but could never get my bike to start from the first try at “COLDâ€Â. For a long time I was looking at the left throttle body and the black box attached to it, the one with the 2 screws painted with blue color paint. On my bike only one screw was painted. That is the switch that dealer and the owners manual says “DO NOT TOUCH†or your warranty is gone. I was really tempted to “TOUCH†it but one day witnessed at the dealership how my riding buddy was charged 6 hours of labor for replacement of that switch. A while back I have stumbled upon some writing about the adjustment of that throttle switch. I just pinched the last (from left to right) wire with the needle and checked the reading with the Volt meter. Sure enough, the setting was way off. Since I am at the sea level, the reading was suppose to be 390 mVolt. The actual range is from 370 to 400 mV. My Volt meter was reading 250. Of course it did not take me 6 hours to adjust 2 screws, but it did take some time to get it right. You tighten it just a bit and the Voltage changes drastically. Since I got it at 390 mV, my bike always starts form the first try, regardless of the temperature. I keep the RPM at 1050 and my bike loves it. I don’t know if this will solve your problem, but it sure did solve mine.
Good luck.
Good luck.
Lifetime Member #586
2004 R1150 ABS
2003 F650 CSA
PRESSING "1" FOR ENGLISH!
2004 R1150 ABS
2003 F650 CSA
MikeCam
- Centurion Moderator!
TIC Tac has opened the 'secret box'.
If you choose to do a TPS reset - and TT is dead on right that it is not guaranteed that any dealer bothered to get it right - be certain to read all you can about the procedure and pitfalls before acting. It is not hard, but the penalty for failure is steep.
M
M
2004 R1150 ABS
2003 F650 CSA
2004 R1150 ABS
2003 F650 CSA
I would suggest to those that are having dificulty starting their bikes in somewhat temperate weather to do the following.
A) Use ruddy's technique which BTW is excellent
B) After the bike is warm verify that the "choke" increases the rpm at both the middle and fully choked position. You might want to note the values.
C) If the rpms increase significantly I would suspect that idle adjust and TB sync might be in order. Of course these can also be affected by the condition of your air filter, valve lash, plug gap, etc.
D) You might also ask the dealer to check the TPS voltage at idle. It should be from .360 mv to .410 mv, the higher number makes for a richer idle mixture.
Good luck.............
