Page 2 of 4
Re: Muffler off; Mileage up
Posted: Mon Jun 02, 2008 8:13 pm
by Beemeridian
11
Posted: Mon Jun 02, 2008 8:29 pm
by Ves
Simple... put the muffler back on for the same amount of time you've had it off... do the same ride... and see if mileage goes back down... take the muffler off... see if it goes back up... if all that confirms you're findings than you know it's real... otherwise it's just a coincidence...
I've had my muffler off for over a year... my mileage is about the same... it doesn't overheat... doesn't run weird... just sounds louder and deeper... sounds good through the earplugs... don't think I'd do that if I rode without earplugs.. Well, I'd still probably do it cause weight savings is a good thing...
Posted: Tue Jun 03, 2008 2:15 pm
by Dr. Strangelove
rdsmith3 wrote:Do you have your Cat Code Plug (CCP) in or out?
hey, Bob,
Don't even know what that is, nor where it is.
Posted: Tue Jun 03, 2008 2:34 pm
by Dr. Strangelove
Ves wrote:Simple... put the muffler back on
Yeah, Ves, I know, but my remaining testosterone levels suggest the can stays off, while my diminishing energy levels demand it.
Yesterday I filled again--the light started going on just under 170 this time and my mileage was 45, with half and half city near-hooligan and the other half steady 70. This was the lowest it has been since the muffler came off.
Posted: Tue Jun 03, 2008 3:03 pm
by Beemeridian
11
Posted: Tue Jun 03, 2008 7:24 pm
by Dr. Strangelove
The spot where it looks like there is a bulb stored in blue mesh has a plug with a yellow relay(?) in it--for my ABS???
The spot where the CCP lays is empty. What is it and what does it do?
Posted: Tue Jun 03, 2008 8:10 pm
by Beemeridian
11
Posted: Tue Jun 03, 2008 8:24 pm
by Sunbeemer
Since you asked...
The CCP is a plug with a shunt wire inside that shorts two terminals to program the Motronic computer to use a specific fuel map for operation in different countries. The CCP modules make different connections for different countries and are different colors (US is yellow). It is a simple way to program the bike's computer to control the fuel/air mixtures to keep the emissions within each nation's environmentally regulated emissions standards.
For instance, our US bikes are programmed to let an Oxygen sensor control the air/fuel mixture to reduce emissions while maintaining the efficiency of the catalytic converter, as well as operate a vapor recovery system solenoid that keeps unburned vapor from being emitted to the atmosphere. If you pull the CCP out, the bike will run richer (and possibly better), but after some time, so I've been led to understand, this will plug the catalytic converter with unburned carbon deposits that could ultimately reduce performance by causing excessive exhaust back-pressure.
Speaking of which, perhaps your old can was plugged up causing more back-pressure and removing it is letting your engine breathe as it should? Just a thought as to possibly why your mileage went up so dramatically after removing it.
Posted: Tue Jun 03, 2008 8:40 pm
by Dr. Strangelove
Thanks,
I bought the bike used and a previous owner must've removed it.
I do notice the exhaust has a bit of a rich smell to it, more when the muffler was on.
Posted: Tue Jun 03, 2008 8:46 pm
by DJ Downunder
Dr. Strangelove wrote:Thanks,
Many BMW dealers remove them when you have a service done without even telling you..It often fixes surging issues.
Posted: Tue Jun 03, 2008 10:46 pm
by iowabeakster
Doc,
Your bike probably came without one. That means it is Euro mode... or was it Yankee mode... I can't remember.
http://www.r1150r.org/board/viewtopic.p ... &hilit=CCP
Posted: Fri Jun 06, 2008 8:09 am
by KHaynes
Perhaps with the extra noise you are lighter on the throttle resulting in a fuel saving. 17% is a huge reduction. Perhaps it's a real saving because the can is off.
Whatever the cause, I wouldn't be complaining.
I much prefer the sound of an R a la DJ. I have heard his bike and much prefer the sound to the OEM setup.
Posted: Fri Jun 06, 2008 2:15 pm
by Airman
rdsmith3 wrote:Dr. Strangelove,
If I can get a little more mpg, I may take that muffler off again.
I am running without the CCP, and have been doing that for years.
I'm interested in that too. I have been running without it for quite a while, believing it helps the surging a bit. My mileage actually went down a bit. My current setup is a Remus y-pipe and the stock muffler. I am going back to the CAT only with one of those chrome DJ tips on it. My daily round trip is about 40 miles so a little milage gain would not hurt my feeling any. In the different configuations I do not recall a mileage increase. I have never got more then about 38 mpg with my mixed town and freeway riding.
Posted: Fri Jun 06, 2008 3:13 pm
by fj_pastor
I removed the can and run only with the tip.
I also use 98 octane fuel.
Results:
- Deeper sound, more torque at lower rpm but ........
No power drop at 4.000 rpm :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D
The bike now runs incredibly smooth from 2.000 rpm to 7.000 rpm
It is a single spark model
I cannot be more happy.
(PS. I also tried the Chitown recipe for the Pirelly Scorpions Sincs and the handling is magnificent !!!! )
Best regards to all
Posted: Sun Jun 08, 2008 9:17 am
by Dr. Strangelove
latest tank, Light came on steady at 172; filled at 179+ and it took 3.62 of 89; mpg 49.44+
This was mostly cruise controlled 70mph per Zumo, prob 2/3--but against some 25 mph winds for most of that; and 1/3 hooligan jack rabbit starts, up to 4th/5th gear city.
JOhn
Posted: Sun Jun 08, 2008 6:28 pm
by Beemeridian
11
Posted: Mon Jun 09, 2008 12:49 am
by Airman
Doc,
Not wanting to be left behind in the race for higher mileage, today I re-installed the CAT, put on a 6" high milage pipe extension, and out the CCP back in. After the usual pulling of the #5 fuse and clacking the throttle 5 times I'm ready for huge mileage increases.
I'll let you know.
Airman
Posted: Mon Jun 09, 2008 10:10 am
by rdsmith3
Airman wrote:Doc,
I'll let you know.
Airman
I pulled the muffler on Saturday but I am not going to put the CCP back in. I want to vary one thing at a time to see about mileage.
Alas, I was not able to ride today.
Posted: Mon Jun 09, 2008 3:09 pm
by Airman
rdsmith3 wrote:
Airman wrote:Doc,
I'll let you know.
Airman
I have not had a chance to ride far yet. I'll fill the tank today to start the baseline. I have gotten 38 mpg for a long time, but I have a few miles on him now abd haven't had the CAT on for a while. I didn't notice any surging from the re-installation of the CCP. Probably when I do the 24k service here shortly I will notice better performance in all areas.
Posted: Mon Jun 09, 2008 10:50 pm
by def38
beemerboy wrote:haha so taking off my muffler should not hurt the bike?
the bmw dealer said its gonna make it run lean and hot
Your BMW dealer is correct. Modifying air flow through the boxer by removing the muffler, removing the CAT (illegal), employing after market air filters means the engine now receives more air for a given throttle setting. But are you adding more fuel along with this increase in air?
No, you are not because the TPS is still in the same position and air flow has increased and you have now upset the stoichiometry so carefully adjusted by BMW at the factory. Your engine is now going to run hotter combustion chamber temperatures, exhaust valves and guides are going to run hotter and you may end up doing engine damage (read holes in pistons).
In order to change the fuel/air mix back to the correct ratio, you'll now need a Power commander or some other fuel map device to provide the new fuel delivery rate. Then, your mileage will suffer because you have upset the factory stoichiometry........quit screwing around with mufflers, CAT removal and other hot rodding crap...there is no economical way to extract meaningful added HP from the boxer engine without changing valve timing, turbo charging or other costly engine modifications. You want more noise?....put playing cards in your spokes or buy a Harley. Want more performance?.....loose 15 lbs.........want better handling?.....take an advanced rider course or buy some instructor/track time.
