5th gear is this odd?
- jeepinbanditrider
Re: 5th gear is this odd?
Unless you have a slipping clutch tire diameter is the only other explanation. Varying temperatures, atmospheric pressure and centrifugal force all of which affect rear tire diameter.
Naah, the speed-to-RPM ratio is fixed by the transmission and except for the reasons (slipping clutch, different diameter tires,) mentioned above, the only other reason could be a different gear. Could you be losing count of upchanges and be riding around in fifth instead of sixth? Or maybe your gearchange to sixth isn't happening properly.
Maybe somebody is switching your bike back and forth with an exact duplicate that has the lower top gear.
Sneaking in the switch at gas stops?
- AirForceDirt
That would explain my gas mileage deficiency. Couldn't have ANYTHING to do with the fact that I spend weekend chasing down R6's or anything. I should put an identifying mark on it somewhere only I know where it-..no, stupid dog, don't pee on my wheels..NOT WHAT I MEANT BY MARK!!
Bike details: 2004 RR 11k
So I did some reading online and I have a better understanding of my gear ratios. Thanks for the push in the right direction. While reading I came across this formula for converting engine RPM, gear ratios, tire radius into MPH:
MPH = (Engine RPM * Radius) / (Final Gear Ratio * 168)
I located the formula here: http://www.msgroup.org/forums/mtt/topic ... PIC_ID=150 Pretty good explanation especially if you are like me trying to learn.
According to the author 'final gear ratio' is a product of all gears involved, primary reduction, secondary reduction, the selected gear from the transmission, and the final drive. Does the RR have a primary and/or secondary reduction before the gear ratios, and what is this value? I search my documents here and came up short.
I already have the values for gear ratios 1-6 and the final drive courtesy of MikeCam THANK YOU. Are the primary and secondary reductions somehow included in those numbers?
I estimate the rear wheel radius is 12.52 inches. So with just a little more info I think I satisfy my curiosity.
OH I tried solving without the primary and secondary reduction values and came out with 3860 RPM at 60 MPH in 5th gear and 3430 RPM at 60 MPH in 6th gear. I do not believe this is correct. The value is too low for 5th and too high for 6th... at least on my bike.
Anyway thanks for the help, or taking the time to read my ramblings.
- AirForceDirt
The rear wheel radius is 17 inches at the wheel, not the tire, so you'd have to add whatever the height of the tire is. Could be why the numbers are off.zeke wrote:Bike details: 2004 RR 11k
(I think that 17 inches is the diameter. Divide by two to get the radius of the wheel, add the height of the tire... Might be close to twelve point something.)
- AirForceDirt
Okay, I feel stupid...mixing up radius and diamter
Your tire is close to 4 inches tall? Damn. Glad I'm running a narrower, shorter tire.
Yeah I was surprised by the height of the tire also.
It is a beautiful day here in DC so I'll probably be out collecting research data....yeah that's the ticket!
