New to the forum, have some mechanical questions
alevin2352
Donating Member #: 968
Re: New to the forum, have some mechanical questions
Post by alevin2352 »
Thanks! I didn't use GS-911 but did have to adjust TBs with twinmax at 6000 miles...It feels smoother but I don't know if placebo or not..
alan
David R
Post by David R »
deilenberger wrote:
alevin2352 wrote:SNIP
I haven't done a camhead engine yet - which will be interesting since it will be almost impossible to get the valves as close as I like to see them (+/- 0.001") due to the step sizes of the semi-spheres used to adjust them.
I checked the valves and balance on my camhead at 6,000 miles. The TBs were closer than I could adjust them on my oilhead. I took the gauges off and rode the bike.
I have found valve adjustments only make a small difference in balance anyhow on all 4 on my bikes. The last one was a Versys twin which had 5 valves out of spec. I adjusted the valves, put the manometer on and had almost no difference.
The last two bikes were done around the same time. Engine temp would change the balance a little. Not enough to bother with.
Loving the camhead!
Getting a GS-911 to put that silly service reminder out. I already did the service.
David
