SignalMinder
Bud
Signalminder
Post by Bud »
Ditto to everything said. I love the paddle on-off feature and the timer. Use the running lights and people see me.
I accidently pushed the emergency flasher and couldn't turn it off either. My non-MC friend walked up and asked me what the problem was (he's a real bright guy). I told him, he looked at the bike and then pushed the BMW signal canceling slider button which I never use anymore and viola! the flashing lights shut off......felt pretty stupid.
Bud
Member #296
"Time flies like an arrow....fruit flies like a banana." Groucho Marx
philm35
Post by philm35 »
Question for those who have hooked up the brake light wire on ABS bikes...
Any problems with ABS faults?
--Phil
touchton
Post by touchton »
I've had my SignalMinder, with brake light wire connected, for over 2 years and haven't had a problem.
BobFV1
Post by BobFV1 »
philm35 wrote:Question for those who have hooked up the brake light wire on ABS bikes...
--Phil
Phil - I have the Kisan SignalMinder brake light and the GizmoMill flashing LED tail light and the Givi V46 supplemental top box tail light kit all hooked in to the brake light circuit and have had no faults in over 15000 miles of riding.
Bob
philm35
Post by philm35 »
Cool. That's exactly what I was hoping to hear.
Thanks, Bob.
--Phil
sshallen
Post by sshallen »
Slight hijack...
I have a Givi top box with brake light. It works fine, but when I am braking, the box shakes a little and the light goes on and off.
The connections (under the box, and under the lid) are clean and shiny. The four spring loaded contacts all seem strong.
1. Does yours do this?
2. Any suggestions?
To test, with key on but bike off, press rear brake with right foot, jiggle top case, look at brake light.
THANKS
Profit is an opinion. Cash is a fact.
tipstall
Donating Member #: 487
Post by tipstall »
taosports wrote:Eight second delay + running lights
Worth every penny
Previous thread with install photos :
http://r1150r.org/board/viewtopic.php?t ... nal+minder
That link dosn't work and I searched and could not find it, can you help?
Silver '04 R1150R
#487
taosports
Post by taosports »
Worth every penny
Tipstall :
Don't know what is going on...that link did work when I posted it - I checked it twice. Now I can't find the thread at all using the board's search feature. :?
If I have any luck, I'll post it again here.
silver
Post by silver »
Does anyone know if you can run just front running lights or do you need to run front and rear together? Also, does the signalminder change the way you use the controls? I like the signal functions the way they are now!
tipstall
Post by tipstall »
silver wrote:Does anyone know if you can run just front running lights or do you need to run front and rear together? Also, does the signalminder change the way you use the controls? I like the signal functions the way they are now!
I don't see a way to run the front only. I installed mine and like it. I have the running lights on high for daylight.
Silver '04 R1150R
#487
Boxer
Donating Member #: 2
Post by Boxer »
The Signalminder is the one best add-on to my bike. I love the self-cancelling/cancelling with same paddle feature.
The running lights I leave on low all the time. I HAVE switched to high on occasion during the day but I usually forget to do this. I worry some that they may get too hot to have them on high all the time.
I have the clear lenses/amber bulbs set-up and was concerned at first about the legality of running amber lights all the time, but I don't think any LEOs are aware of it, or just don't care. Never been ticketed or even asked about it.
silverrr
Post by silverrr »
Hmmm, good info, I had been concerned about the heat issue. I was also thinking that it might be illegal to run rear runnings lights, I dunno why but I have only seen them on the front of other bikes. Either way, sounds like a good purchase!
