Throttle Cable Adjustment and TB Synch
Apostle
Post by Apostle »
cmack wrote:...After doing numerous TB synchs, I've come up with a way to get the best synch possible every time with no throttle slop. It will take a little longer the first time, but the majority of the work can be done with the engine turned off and the results are worth it!
Craig,
That was the best (and what is also very important condensed) advice for TB synch I ever seen! Your technique is summarizing all those hours I spent playing around TB synchronization.... What I had (partially and unclear) in my head is now clearly written on the paper. You are THE MAN, Craig! I live in Seattle, but if one day I'll visit Georgia I insist to buy you a beer. Thank you A LOT for your post and effort in creating step by step procedure!!!
TO MODERATOR: I would suggest saving this post for the future reference. It is definitely a winner candidate for a STICKY TOPIC which will help to save hours of time and explains clearly what and how to do to have TB in perfect synch. It IS a real practical advice which works great!
Apostle
Apostle
'04 Silver R1150RA
'01 Green ZRX 1200R
Apostle
Post by Apostle »
Boxer wrote:2wheelin-Thanks! It was the September '05 issue and I just read it. It pretty much explains what I needed to know, but still does not address the connection between the throttle cables and the 2 TB cables. This is a great article BTW, for those about to do this with the TwinMax.
Boxer,
If you don't mind could you post here a URL to that Spetember' 05 issue, so I have it my "servicing docs collection". I couldn't find it (most likely I'm searching in a wrong place).
Thank you in advance,
Apostle
Apostle
'04 Silver R1150RA
'01 Green ZRX 1200R
