Know your bike 101 - Caliper bolts (In honor of boxermania)
Posted: Mon Jul 16, 2007 7:29 pm
by DSKYZD
In honor of our old friend Al aka boxermania, I present this little poll about torque values for brake caliper bolts front and rear. How well do you know your bike?
Posted: Tue Jul 17, 2007 2:17 am
by GTR350cc
About a buck two fifty.
Posted: Tue Jul 17, 2007 5:37 am
by DSKYZD
Posted: Tue Jul 17, 2007 9:01 am
by riceburner
as tight as they'll go with the correct tool and "palm pressure"
Posted: Tue Jul 17, 2007 11:29 am
by jm1515
Anything that insignificant that I can look up I don't clutter my head with....
Posted: Tue Jul 17, 2007 11:40 am
by Boxer
I just had new rubber put on last week and I took the wheels off to have that done at my tire place. So I remembered the 30nm. But normally I never remember the torque on anything so I am constantly referring to the little manual.
Posted: Tue Jul 17, 2007 11:47 am
by DSKYZD
jm1515 wrote:Anything that insignificant that I can look up I don't clutter my head with....
So when you look it up, what does it say?
Posted: Tue Jul 17, 2007 12:41 pm
by Beemeridian
234
Posted: Tue Jul 17, 2007 1:37 pm
by Croc
I've just replaced the pads this weekend. So here's a clue - the front is different to the rear
Croc
Posted: Tue Jul 17, 2007 2:39 pm
by Boxer
Okay, here's another clue.
Posted: Tue Jul 17, 2007 4:27 pm
by iowabeakster
did i win anything for having the first correct answer? we did have 100% correct answers at the beginning. downhill slide ever since.
i can't believe Boxermania has sold the bikes. we will miss you, mania.
Posted: Tue Jul 17, 2007 5:45 pm
by DSKYZD
...and the clues lead us to different answers.
Whether you voted correctly or not depends on the source you trust.
As Boxer has shown, the little service manual shows 30Nm front and rear. However, the R1150R Repair manual lists 40 for the rear in both the torque values table at the beginning of the book (p.9) and in the procedure section for removing and refitting the rear brake caliper (p. 34.6). The front value is 30 for all sources.
So which one MORE correct?
Posted: Tue Jul 17, 2007 10:38 pm
by owldaddy
Tighten it till it strips, then back it off 1/8th turn
Don
Posted: Wed Jul 18, 2007 12:49 pm
by Croc
My little Maintenance Intruction Manual that comes with the bike lists in Sec 2 page 34 that the rear wheel brake caliper screws are 40nm. It shows a pic of the BMW brake calipers whereas Boxer's picture shows the Brembo brake calipers. Therefore we can assume that the different calipers have different torque settings - ie BMW = 40nm and Brembo = 30 nm.
Do the different years have different brake calipers? Mine is a 2003
Posted: Wed Jul 18, 2007 6:57 pm
by Biff's R
As tight as I can get them with my 36" ratchet. I would guess it is something like 200 NM.
Posted: Fri Jul 20, 2007 9:11 pm
by DSKYZD
Croc, you may be on to something.
My 2003 has BMW Calipers. My little Service manual says 30Nm and looks just like Boxer's with Brembo calipers pictured for the rear. It has BMW calipers pictured for the front.
I know someone with a Rockster who confirmed their little service manual says 40Nm for the rear.
So it may be that they either changed the spec around 2004, or they changed the spec when they began using the BMW "branded" calipers. Hell, maybe BOTH, or NEITHER. The Repair Manual I refer to says it was printed in Germany 07/01. What do you think of that?
All this brings back the memory of the first time I removed my rear brake caliper. I didn't think I was going to be able to do it with the tools in the kit, even using the "extension" for extra leverage. It's never been that hard since. I would have done 30Nm the times I've the rear wheel off. I don't know that I've had the dealer remove the rear tire since the first time I did it, but they removed it when they my first set of Z6's on.
What will do when I put my rear tire on? 30 or 40? Hmmm, couldn't tell you right now. Maybe I'll repost once I do it.
DSKYZD
Posted: Sat Jul 21, 2007 4:26 am
by Croc
My manual was printed in Germany - 2002 and states 3rd edition.
Who knows
Who cares
Maybe BMW dont even know
Caliper Logos
Posted: Thu Jul 26, 2007 10:03 pm
by marecycling
I believe that the calipers that have the BMW logo are the Evo Brake System calipers, which provide better stopping, less lever pressure needed to activate, and lighter weight. Pads may be replaced without removing the calipers. These designated calipers have the lower torque values, both front and rear. I believe they were introduced in the 2002 model year.
