Doing my first oil change...
Does anyone have a list of the tools needed?
Also, for the oil filter cap wrench, does anyone know the exact size and number of sides? I have quite a few already at my house, so I'd rather not buy another cap wrench if I don't have to.
I plan on doing the 15w50 synethetic unless other people here recommend something else.
I don't think I need to do the tranny/FD fluid, as it was changed during the 6k mile service. If it's suggested to change that also (I remember reading some people use a thicker fluid), then I don't mind doing that at the same time, too.
Thanks.
- Anthony
Thanks.
- Anthony
The cap wrench size is 76 MM. You can find them anywhere. A generic that costs between $4 to $10 works fine.
BMW service experts recommend changing the final drive oil with 80W-90 dino oil at the same time you change the engine oil.
The 15W-50 synthetic oil should be just fine.
Rick
2003 R1150R: Silver
Lifetime Member #585
2003 R1150R: Silver
I have a 76mm 14 sided one. Same as the filter cap for a lot of the mid 90's Mercedes-Benz's.ruddy wrote:The cap wrench size is 76 MM. You can find them anywhere. A generic that costs between $4 to $10 works fine.
OK, so how do I change the final drive oil? I saw they used Amsoil 75w90 during the 6k service, but I don't know if it was for the tranny or for the final drive.BMW service experts recommend changing the final drive oil with 80W-90 dino oil at the same time you change the engine oil.
Does anyone have any tech specs on this oil?The 15W-50 synthetic oil should be just fine.
I will need a filter and I assume drain plug/washer, and the oil. Where should I order from?
Try Bob's BMW. I use the Bosch oil filter, and be sure to ask for the crush washer if you MUST replace it, I don't always.
I just buy my oil from the local discount auto parts, Mobil ONE 15w-50,(engine) and 80-90w gear oil for both the trans and final drive.
Yeah, I may just call bob's and have the mship that stuff to me.OU812 wrote:Try Bob's BMW. I use the Bosch oil filter, and be sure to ask for the crush washer if you MUST replace it, I don't always.I just buy my oil from the local discount auto parts, Mobil ONE 15w-50,(engine) and 80-90w gear oil for both the trans and final drive.
I didn't know if it was a crush washer or not, but I always replace crush washers. Of course if you want to save $.50, you can always reverse the crush washer and reuse it once.
I read somewhere on here about using a heavier weight synthetic oil for the tranny? Can anyone comment on that? How any quarts do I need for the tranny and the final drive?
Also, How often do these fluids need to be changed?
Check out http://www.beemerboneyard.com! Super fast shipping from NJ to VA. They've even got full 12K service kits. You said the FD was done at 6K but is normally a 12K item. Some people do the FD fluid w/ the oil because it is so easy.
I use 15w50 Mobil1 in my engine now. Synthetic in the engine doesn't get recommended until about 18,000 miles to give those hardened parts time to mate well.
http://www.beemerboneyard.com/newparts.html
DSKYZD
DSKYZD
JOURNEY JUNKIE #187
Thanks for the link.
The spark plugs were done at 6k, so I"m not going to worry about them. Same goes for the air filter.
I just want to put in some synthetic motor oil, and hopefully using a heavier weight trans/final drive fluid will help with the "clunkiness" of the transmission.
I have never really believed in waiting for xxxx miles before putting in synthetic. Granted in my cars I leave the factory fluid in for a few thousand miles, but then switch to synthetic.
For what it's worth, Porsche's come with Mobil1 0w40 as factory fill...
I see this listed on Bob's BMW:
BMW 75w140 Synthetic Gear Oil - $17.39
BMW 80w90 Dino Gear Oil - $8.79
BMW 15w50 Synthetic Motor Oil - $11.90 (:eek:)
Aren't some people using 75w140 in their transmission?
I may just run Mobil1 15w50 in the engine... How many quarts? I think I remember reading just over 3?
As for the gear oils - are these all GL-5 fluids? I would assume they are.
I may just go straight Mobil1:
Mobilube HD Plus 80w90
Mobil1 Synthetic Gear Lube LS 75w140
Yes they are, bigger. The final should be a magnetic drain pug, so you can see how things are going in there. A little gray goo is not bad.adg44 wrote:Excellent. Then a gallon of Mobil1 15w50 Extended Performance it is.OU812 wrote:Almost 4.OK, maybe 3.5
Are the crush washers different for the transmission/final drive compared to the oil drain plug?
the one tidbit I've learned;
make sure you get the filter on tight - don't over tighten. But you want to make sure it's all the way screwed on or it will drip a little. Easy to check after the first ride and tighten if it needs it.
Gaston #1135
'03 R1150R Black
'99 Suzuki Bandit 1200 BRG
El Cerrito, CA
'03 R1150R Black
El Cerrito, CA
I see you're in Reston - not too far from me. I may be going up to Bob's this saturday to get some maintenance stuff and I can pickup whatever you want and bring it back. As for the oils, you can buy good brand oils at the closest Autozone/Advanced Auto and save some money.
Now that I'm looking at the link to the service kits from BeemerBoneyard, that may be a good deal: http://www.beemerboneyard.com/r1150dsmaintkit.html
I'll let you know about this weekend and Bob's.
Member 293 (I think)
'17 Triumph Tiger 1200 XRX
That's very nice of you!R4R&R wrote:I see you're in Reston - not too far from me. I may be going up to Bob's this saturday to get some maintenance stuff and I can pickup whatever you want and bring it back. As for the oils, you can buy good brand oils at the closest Autozone/Advanced Auto and save some money.
I may be going up there on Friday actually, as we have an office in Hanover (not far away).
Or, I may just order the filter and the crush washers. I will be using all Mobil1 products since I can get them at Advance.
- Anthony
OK, I just called Bob's BMW and ordered:
Part # 11421460845 - $14.95. I know there is the Bosch filter for $8.95 - but that's the generic Bosch stuff and I don't like it. Actually, I don't really like any Bosch products!
They also sell a crush washer kit. It's a good thing I asked for part numbers, because she originally quoted me the part for Air Heads and not Oil Heads. She was nice, but sometimes parts people are hit-or-miss.
It is Part # CWR11 and has 5 crush washers (two for FD, two for Tranny, one for oil) and costs $3.99.
Add in $6.95 for shipping and it will be here tomorrow.
- Anthony
- Anthony
