Holy COW! 17K on a Metzler Z6 rear!
Lion_Lady
Post by Lion_Lady »
I was so stunned when I did the math, that I called the shop to make sure I hadn't left an invoice out of my record book. Replaced the rear in June '06 at 13,230 miles. Just replaced it today with 30,300 miles on the bike. :shock:
The front was replaced in April at 21,300 miles, and it still looks fine. Been commuting about 60-70 miles daily, the last 5 months. Half of the ride is highway, the other, nice winding two lanes.
P
Tripton
Post by Tripton »
Wow. That is really impressive!
I get 4 or 5k.
Of course, I am heavy and i beat the hell out of my bike...
RBrider
Post by RBrider »
You've got a gentle touch! My Z6 had about 4K when it came off the bike.
RB
Post by riceburner »
RBrider wrote:You've got a gentle touch! My Z6 had about 4K when it came off the bike.
RB
I get a little more than that out of Pirells Diablo Stradas (sametyre in all but tread pattern), something like 5 - 5.5K miles.
RB
citrusbbee
Triple Lifer
Donating Member #: 553
Post by citrusbbee »
Lion Lady,
I've had the same good luck as you. Put a set of Metzeler Z6s on my R850R at 17,500 miles. I've put 14,500 miles on them, and still have a couple thousand left in the tread!
Citrusbbee
Member #553
'04 Rockster Ed80 (#967)
'15 R1200RT
DYNAMICS
Post by DYNAMICS »
Hi Lion_Lady.
What F/R pressure do you run?
And... riceburner are you still running on 36/42?
BMW R 1150 R Rockster (The best kept secret!)
\\Mike_Lea//
Post by \\Mike_Lea// »
I run 42 rear / 36 front on my Stradas (like RB) which is the manufacturers recommendation...
M :)
Shine on you crazy diamond
DYNAMICS wrote:Hi Lion_Lady.
Yup, as MikeLea says - it's the Pirelli recommendation and it feels fine.
Darn Lion_Lady.....you must weight 80 pounds wet and fill the tires with Helium.....that is outstanding mileage. 8) 8)
fnfalman
Post by fnfalman »
I got about 9-10000 miles out of my Z6 and Strada rears.
jfslater98
Donating Member #: 535
Post by jfslater98 »
My rear Z6 is looking a little raggedy after a few thousand miles, especially in the center. Is that normal for mostly highway miles? How stringent are you guys in keeping the air pressure in the 36/42 range before you fill up again?
MikeCam
Centurion Moderator!
Donating Member #: 100
Post by MikeCam »
Tire pressure has some leeway but generally speaking, once you choose your preferred pressure, every ride should start there. Daily pre-ride checks of oil and air pressure are a minimal safety standard.
jfslater98
Yes, the checking I do every ride. It's the filling part where I get lazy. :oops: Not helping is the disappearance of free air. :? So right now, I know my rear tire is at 37psi. And I'll let it get down to 35 before I do anything. Is that bad?
DYNAMICS
Post by DYNAMICS »
As little as 2-3 psi can affect how a motorcycle handles, and can alter the running temperature and wear rate of a tyre.
Buy a bicycle type track pump and a good quality pressure gauge, and it is a 4 minute job. (Also it will be "clean air" not full of moisture like some petrol station machines!)
DYNAMICS wrote:As little as 2-3 psi can affect how a motorcycle handles, and can alter the running temperature and wear rate of a tyre.
Agreed.
I can "feel" that something's wrong with as small a difference as 1psi off normal.
Lion_Lady
Post by Lion_Lady »
When I ran 36 psi on the front, it got badly cupped too soon.
I run front at 38. Rear at 42.
To tell the truth, after examinining the NEW Z6. I noted that there is only about an INCH between the "points" of the tread grooves. On the old tire, there was over 2 inces of smooth rubber down the center.
I probably should have switched a couple K sooner.
P
reidmct
Post by reidmct »
I think the major determinants of tire life are:
Road surface
Pressure
Weight
Speed
On my ZZR1200, which weighs about 70 pounds more than my Rockster, I destroyed a rear Z6 in under 3200 miles. I was running 38 pounds, on chip-seal roads (awesome traction, but like a cheese grater), frequently exceeding 100 mph, averaging 80 mph.
Reid
joe bar
Post by joe bar »
Currently have 5,000 on my rear Z6, including a trip to the Pyrenee's, one to the Lakes and one to Scotland, ridden loaded and pretty hard. Still has good life in it. Pretty impressed really.
