Putting something useful in the clock hole......
touchton
Post by touchton »
A few years ago Jon Maddux went though some pains to replace his clock with an oil temperature gauge. Since that time I've been meaning to order a gauge and replace mine. However, since procrastination is one of my best qualities, I never got around to it. Not long ago sweatmark mentioned he had the gauge and sender and was willing to sell it. I purchased it from him and had some time today to install it.
The installation is quite easy. The only 'special' tool needed is a 1/8 - 27 NPT tap for mounting the sender. For instructions I used the information that jabrooks has put together located here: http://home.mindspring.com/~jabrooks/te ... m#ezcrusty Here are some pictures and details of how I installed the oil temperature gauge:
Here's a picture of the clock and the gauge. I removed the rubber ring from the clock and placed it on the gauge. I didn't use the old mount on the back of the clock to mount the gauge. This VDO gauge has a mounting ring which made the mounting easy. Image
This shows the gauge wired and ready to install. I used a couple of short pieces of wire to jumper one side of the light to the positive terminal on the gauge, then pig-tailed out to connect to the old clock's wiring. I did the same for the other side of the light and ground. All the connections are soldered and insulated with heat shrink tubing. The long black wire is for the sender.
Here's the gauge installed in the instrument cluster using the mounting ring. The positive and ground wires are connected. I taped off the un-switched power connection that had been used by the clock. The ring mount worked perfectly. I did have to use part of the old mount just to hold the torx screw plate back in place.
And, the front view. This gauge has a black front mounting ring. From what I understand, they also can do chrome.
I didn't take any pictures of the sender. The details of mounting the sender are in web page jabrooks created. There wasn't much to it; tap the hole and screw it in. I did put some heat sink compound on the end of the sender in an effort to ensure a good thermal bonding. Once I had everything back together, I took it out for a ride. Just a short ride because it was horribly windy here today and a bit cool. The gauge appears to have a bit of moisture behind the glass. I'm sure that will clear up after a sunny day of riding. The gauge worked great. The temperature runs just over 200 degrees. It will be interesting to see the difference in highway and stop and go driving.
MikeCam
Centurion Moderator!
Donating Member #: 100
Re: Putting something useful in the clock hole......
Post by MikeCam »
LOOKS FACTORY!!!
The highest praise for a home done mod!
Byrdguy
Post by Byrdguy »
Nice job. Do you want to sell your clock? I need one, mine got damaged in a mishap. PM me if you do.
CorvuS
Post by CorvuS »
Looks very nice! Too bad i got a digital clock on my bike :lol:
sweatmark
Septuple Lifer
Donating Member #: 208
Post by sweatmark »
touchton-
Nicely done. Glad the Maddux VDO gauge worked out for you. Guess there's a bit of Oregon drizzle-winter moisture in that gauge! Nice to see the oil temp mod in use... never could talk Mrs. Sweatmark into replacing her clock once she inherited the Roadster.
FWIW, I ordered the gauge from Palo Alto Speed Shop in case anyone's interested in doing dimilar Roadster mod. And the trim ring is (or was) available in a couple of finishes; I chose black because of the glare I often noticed from the Roadster's chrome clock trim ring.
touchton
Post by touchton »
Byrdguy wrote:Nice job. Do you want to sell your clock? I need one, mine got damaged in a mishap. PM me if you do.
The PM function is down, but wanted to let you know the clock went our Priority Mail today. You should have it later this week.
Thad
Byrdguy
Post by Byrdguy »
Great, Thanks again, Thad.
