Technical Advice Regarding Front Rotor Attachment
bluelight
Post by bluelight »
I took a ride down to a local beach on Sat just to go for a ride.
I got into the parking lot and noticed a creaking sound comming from the front wheel
as it went around, only in a tight left turn at walking speed. Lasts for a half second at most,and is high pitched.
So I got off got the gear off and went down to the beach for a while, but not much sun.
Ok, not much sun, but the ride was fun. I went back to the bike and decided to look at the front wheel. (note had the wheel and rotors off since I got the wheel straightened
and new tires put on last week.) So to my suprise the rotors didnt seem snug with the
wheel there seemed to be a 32" inch gap (maybe less) and you can watch the rotor move
when you push it towards the wheel. Both sides are the same. So I didnt have the tool
kit with me so I couldnt tighten the bolts so I rode home slowly. I found the wrench for the rotors and found the bolts tight. So next I put it on the center stand and spun the front wheel and it spun freely with one section rubbing just a bit.
Tonight I had a brainstorm, lets look ant the rear rotor. Well it looks glued to the wheel.
So my thinking is that the front should be the sme way! Is my logic correct?
Thanks for your advice, you guys are great.
Doc :?:
I just thought to compare the
