ABS Red Light
Posted: Thu Jun 05, 2008 9:17 am
by homerr1150r
Hi, when I start my bike in the mornings I get the red ABS light come on. On tick over it stays on but as soon as I twist the throttle a little it goes out and stays out? Does anyone know if this is normal or do I have a problem? (Yeah I know I have a problem) but does the bike?
Re: ABS Red Light
Posted: Thu Jun 05, 2008 9:51 am
by bikermeow
It should stop flashing go off when you hit about 15 km/h, after it had self-diagnosed.
cheers
Cat
Re: ABS Red Light
Posted: Thu Jun 05, 2008 10:07 am
by Gordium7
The ABS runs diagnostics and calibrates itself. The front wheel needs to spin past the ABS sensor a certain amount (like one or two revs) which is easily accomplished in the first 10 feet or so of movement.
One note of caution: The system does not like you using the brakes during this diagnostics/calibration period. The only time I remember running into a problem is if I happend to be backing out of a parking space and need to use the brakes due to a sloping surface, etc. In that case, the diagnostics may fail and the ABS brakes won't work -- it will be pretty obvious and the light will indicate this. The simple solution is to turn off the engine a few seconds and start over -- this has always cleared up the problem for me.
It does make me pay a bit more attention to where/how I park the bike.
Re: ABS Red Light
Posted: Thu Jun 05, 2008 10:13 am
by homerr1150r
Thanks very much, I can stop worrying now.
Re: ABS Red Light
Posted: Thu Jun 05, 2008 10:42 am
by Lobo1625
That sounds less like the ABS light and more like the behavior of the Alternator light. That is correct behavior for the alternator light as well, since it takes a few RPM to get the alternator to self excite and start charging the battery.
