Centech install
Centech install
I recently got a Centech fuse box and relay. I don't want to drill a bunch of holes in the bike to mount it. I saw a pic of a bracket that sits on top of the air cleaner and uses existing screw to mount. I like the idea. Is the bracket for sale or does one have to construct one themselves? I'm sure this topic has been covered but i can't find the thread, sorry.
careful what you ask for
Re: Centech install
I have a Centech on order. When it arrives, FWIW, I intend to use a wide strip of velcro to hold it in place.
2003 R1150R Single Spark Non-ABS
Railbender
Re: Centech install
The airbox mount is from CycleNutz;
http://www.cyclenutz.com/products/elect ... unt_2.html
I just got mine the other day. I have a Blue Sea fuse block and on my R1100R the seat will not go on in the low position.
I had to trim the front of the seat pan to get it to go in the middle position. I am going to remove the tank so I can see exactly what the problem is. I think the Centech is smaller than the Blue Sea so you may not have a problem.
Re: Centech install
Is this a water tight enclosure ? The only real failing of the Centech unit is that it's completely open. I think the Centechs are somewhat smaller than the Blue Sea. The usual Centech mount on the RR is to make a little plate to bolt to those screws where the diognostic plug used to be, or perhaps like Twempie suggested, a strip of velcro.Railbender wrote:The airbox mount is from CycleNutz;
I just got mine the other day. I have a Blue Sea fuse block and on my R1100R the seat will not go on in the low position.I had to trim the front of the seat pan to get it to go in the middle position. I am going to remove the tank so I can see exactly what the problem is. I think the Centech is smaller than the Blue Sea so you may not have a problem.
Railbender
Re: Centech install
It is not water tight. The cover on the Blue Sea has cut-outs for the wiring so the only real protection is from the seat. If water becomes a problem some closed cell foam strips in the cover cut-outs might help.Airman wrote: Is this a water tight enclosure ? The only real failing of the Centech unit is that it's completely open. I think the Centechs are somewhat smaller than the Blue Sea. The usual Centech mount on the RR is to make a little plate to bolt to those screws where the diognostic plug used to be, or perhaps like Twempie suggested, a strip of velcro.
Re: Centech install
Here's what I did a number of years ago, and it works fine w/o having to drill any holes on the bike.
Happy Rider
Re: Centech install
I followed taosports lead and did the same. Works very well for me.
Martin
Martin
2004 R1150R ABS - silver
BMW MOA # 139330
BMW MOA # 139330
Re: Centech install
Happy Rider wrote:I followed taosports lead and did the same. Works very well for me.
Martin
+1 here.
much the same.
mate milled me a 'L' brkt. sits right under the tank, (no water problems in 12 mths) but uses the 2 air box screws to fix
Diagnostic plug moved forward to allow above.
