And for that most important of questions....
klrstix
Post by klrstix »
What do you use to clean the motor itself. Particularly the cylinder head....
An off the shelf engine cleaner does not seem to do too much for me.
Jaguar5
Donating Member #: 706
Re: And for that most important of questions....
Post by Jaguar5 »
I have a small hand held steam cleaner that I have been using for mine. It might sound like a bit of overkill, but it has worked very well and relatively quick. I use it with a long bristled brush and just plain water in the steam cleaner.
I am interested to hear what everyone else is using. If there is something quicker or easier, I am all for it. I just used what I had available...
Blue '02 R1150R
Member # 706
bikermeow
Post by bikermeow »
klrstix wrote:What do you use to clean the motor itself. Particularly the cylinder head....
The bane of proud oilhead ownership .... this will be enlightening. :D
gregor
Post by gregor »
An off the shelf product made by Autoglym and simply called Motorcycle Cleaner. Terpene based (smells of oranges). Spray it on ,rub with a brush and hose off.No problem. Do not let it dry on black engine assembly paintwork as it can cause a lack of shine. White spirit/turpentine may be better for any hard bitumen spots.
Dow Bathroom Cleaner....scrubing bubbles, two inch paint brush and water. On asphalt have to use a disolver first........
frozennorth
Donating Member #: 506
Post by frozennorth »
Spray Nine and a 1.5" hard bristle brush. Also, have a 3/8 inch test-tube cleaning brush for getting into the crevice by the exhaust port 8) Don't leave it on too long before rinsing and don't get it on any other painted or black parts . . . the stuff is evil :evil:
Red 02, R1150R
Member # 506
I am an empty hospital!
dmk
Post by dmk »
Must one be careful using a steamcleaner on the engine? I've read somewhere not to use high pressure around the engine as it might have a negative inpact on certain gaskets (head).
Dan
04 Silver 1150R
