Hello all,
I want to wire an accessory plug from the battery to the handlbars. I found the perfect plug, but I have to ground the ground wire somewhere around the handlebars. Does anyone have some helpful suggestions on where to ground it? Thanks.
Fishbender
Grounding a wire
Re: Grounding a wire
There is plenty of ground cables for example in and around your front light. Just use a multimeter and check the wires.
Kind regards
Oliver
Kind regards
Oliver
Fishbender
OK thanks for the help.
Terry
Terry
