mirror.adjusting.question
dd
Post by dd »
hi.
my rear view mirror came loose.
i studied the design for a while, but can't understand how it is supposed to work.
i truly feel like an idiot for not being able to figure this out on my own.
can anyone explain how to properly tighten the mirror?
thanks.
-daniel.
it seemed like a good idea at the time
ka5ysy
Triple Lifer
Re: mirror.adjusting.question
Post by ka5ysy »
This is the R1200R Owner intelligence test ! :lol:
The lower nuts need to be screwed down with a bit of blue loctite on them. The nut on the mirror end of the stem is a jamb nut that needs to be tightened while holding the mirror in position, and the whole procedure takes two wrenches and three hands to accomplish. A good vocabulary of swear words also helps :!:
Let us know how it works out
MSF #127350 NAUI #36288
2011 RT
dd
Post by dd »
ka5ysy,
thanks so much for your input.
your advice worked perfectly.
i suppose in hindsight it is an obvious solution.
it is just that, as far as i could tell, the factory didn't use loctite during the original buildup, so i was hesitant to use it myself.
there was no residue or evidence of thread lock left on the bolt when i fully unscrewed it, as far as i could tell.
i am no engineer, but this just doesn't seem like a very intelligent design to me.
clearly, those comments are not directed at you, but at the manufacturer.
as for your assistance, i very much appreciate your help in getting my bike back in working order.
-daniel.
My "Mickey Mouse" mirrors did that several times, once when riding through a very congested part of a largish city. I couldn't pull over and stop because I was follow other riders. PITA!
When I replaced them with BMW R1200ST mirrors that problem went away.
It was not immediatly evident to me either how to on-site fix the mirrors. A friend had to come help me and make me feel silly. All in all I think I like fairing mounted mirrors better not just for this sort of thing but for backing up into the garage or shed.
