Defective oil filter valve??
Posted: Tue Apr 20, 2010 11:23 am
I am having a couple of issues after oil and filter change.
2002 R1150RA 9,000 miles.
Just purchased the bike. Local dealer checked it out and said all was sound and good shape. OK, so I wanted to be sure fluids are all new. Oil was very clean and I was told it was new. Still wanted the peace of mind etc.
Drained engine oil. Filled with BMW oil - and filter. Started engine, heard usual clatter until oil pressure went up. Let run a few minutes.
The issues are -
1 Every time I start the engine I hear the clatter for a second or two, then quiets down and runs fine.
2 When you shut the engine off about half the time oil level stays at top of window. Even after 15 min or so.
If you re-start you get the noise again momentarily then quiets down. Turn it off and in 10 minutes level will be at proper mid point on window per manual.
Concerned about excess wear on start up and proper oil circulation. I also notice a hot smell not there before I started.
Not a professional wrencher but change oil in my three cars successfully.
All I can figure is sticking filter valve.
Any suggestions?
Malibu
The issues are -
Any suggestions?
Malibu
