How do you remove the side covers?
Devo3136
Post by Devo3136 »
Subject line pretty much says it all, on a 2002 R1150R, don't want to break anything.
jas
Re: How do you remove the side covers?
Post by jas »
If you are reffering to the side/trim panels this is a good reference:
http://home.mindspring.com/~jabrooks/te ... dywork.htm
If you are refering to the covers on the oil coolers:
http://home.mindspring.com/~jabrooks/te ... emoval.htm
If you click on the "Tech Tips & Reviews" tab in the upper right portion of this screen, a lot of good information can be found.
2004 Roc.
