Switched Power source under seat?
Posted: Thu Jun 17, 2010 5:59 pm
by JohnM
I'm planning the under-seat installation of my Fuzeblock, and I'll need to tap into a switched power lead nearby.
Besides the one at the accessory outlet, is there another one I can tap into?
TY
JohnM
Re: Switched Power source under seat?
Posted: Thu Jun 17, 2010 9:16 pm
by psycle.vt
I mounted the Eastern Beaver Fuse block in the back of the under seat area and routed the trigger wire from the relay to the blue/green switched wire from the diagnostic plug. Works fine. Here is the connection:
Posted: Fri Jun 18, 2010 5:15 am
by JohnM
Thanks Cy! Thats exactly what I'm looking for.
Posted: Fri Jun 18, 2010 8:56 am
by dumfounded
There's a similar green wire (with white stripe) on the connector just aft of the diagnostic plug. It's for the alarm system and does the same thing. I'm using it to apply power to my Hyperlight flasher module with no issues. Personal preference and paranoia leads me to stay off the diagnostic plug.
Posted: Fri Jun 18, 2010 2:28 pm
by Coyote Crazy
JohnM,
You may want to reconsider using the accessory outlet switched wire. Although you did not state your reason for wanting to use another switched sourced, this has worked well for me as well as my Fuzeblock. I installed my Fuzeblock using the accessory switched wire for the switched relay and found it to be a fairly short and easy route to the Fuzeblock. The 2 advantages I see are 1 - that circuit was designed for accessory use and 2- I find the one min. delay in shut off to be very convenient, for example when fueling and keeping my GPS running (key off, unlock fuel cap, key back on, GPS still running). (I am the only one with a GPS in the group I ride with and invariably it is at the fuel stop everyone wants to know how many miles to destination and/or ETA.) I don't believe an extra min. of power to the accessories will adversely affect a healthy battery should you forget and leave something on after you turn off the ignition. What ever source you decide to use, you will really want to consider using a Posi-Tap connector to make the connection. (I was able to locate them at local Carquest auto parts, if not in stock they are in their catalog and usually can have next day.)
Best of luck with your installation.
Fuzeblock Installation
Posi-Tap at back of accessory outlet
