1. Got drag off the parking lot after hit by a car- the bike took it nicely to say it nicely. Truly the valve cover protectors did it's job sliding in concrete. It will be replaced it's badly rashed. The r footpeg feelers are gone. The left side that took the impact has scratches and the valve cover has chips. Otherwise, I'm amazed at how the bike still looks beautiful after the fall. I guess it fell gracefully.
2. So far i only rode it about 200 miles around the city with a lot o stop/go kind of riding. First thing I noticed is how tall the clutch disengaged. Is this normal characteristic of the bike? I'm coming from FJR and I'm used to earlier disengagement. I ended up surging on the throttle most of the time when going through lower gears up to speed. I adjusted the clutch lever to the lowest setting but still..
3. Brakes: Again coming off FJR, its brakes are linearly progressive as you increase pressure. On R12R, the brake would bite but it's not as progressive as you increase the squeeze then.. boom! The bite is abrupt. Is this a normal characteristic? I'm actually getting used to it but could be improved. I checked the pads for wear and all is still good.
The bike is as light as a bicycle coming off a 650lb bike! This bike handles better too. At least in the street. I have tried it in the twisties yet but I can tell already that I wont be disappointed. It's not as powerful as my FJR but the reduced weight made it more fun to ride. It's got aftermarket Hyperpro springs and so far it's a little stiff but I'll leave it at that until I ride it in the fast twisties and long sweepers.
Overall, I'm happy with my purchase (I'm trying to forget about the accident). I was looking for a lighter bike as replacement for FJR but want to keep the shaft drive and this is the only bike the fits the bill.
