Just Bought a 2001 R1150R
Posted: Mon May 16, 2011 2:46 am
by Coyne67
Hello To All,
I just bought a R1150r 2001 model, pick it up next week. It has a lot of K's on the dail 183000 but I could not resist the price and condition. She is pretty much immaculate for a 10 year old, and only one owner who obviously loved her. The service record is faultless continually looked after by the place I have bought it from. I am a bit concerned about the high kilometers does anyone have any feed back on how the R1150R copes with high kilometers, I am hoping I am not going to get caught with a rebuild or something soon. Any input would be gratefully recieved.
Cheers
Paul
Re: Just Bought a 2001 R1150R
Posted: Mon May 16, 2011 4:59 am
by towerworker
Welcome Paul!
You have picked a great board for information on the R. That equates to roughly 113,000 miles and while that's certainly not low miles I have heard of BMW's with far more. If the owner and dealer did the recommended services then probably all the bases have been covered. Hopefully you have read over some of the threads on this board concerning major failures. The two that get most press are clutch spline failures and final drive failure. The former costing much more to repair. I hear of no engine failures at all unless it's related to allowing the bike to sit and idle for long periods of time with no air flow over the cylinders (a real NO-NO). At your mileage(kilometers) I would ask have the clutch splines been checked and/or lubed (most likely not an issue since machine has gone this far) and lastly I would check play in final drive. The link below gives some info on checking for that. ABS is the only other area that can get real expensive. You did not say in your post if yours has that feature. Wonderful stuff that ABS till it goes out! (not common though)
Hope this helps!
And again welcome.....................oh, and be wary of anyone telling you to check your bike's antifreeze!!
viewtopic.php?f=2&t=22693
Posted: Mon May 16, 2011 6:30 am
by Coyne67
Thanks Mate,
I am only new to the blog so I have not had the chance to go through all of the issues yet but as far as I could see from the paper work all of the required work as been done at regular intervals. Thanks for the infor much appreciated.......
Cheers
Paul
Posted: Mon May 16, 2011 6:40 am
by kantuckid
Paul Glaves, guy that writes a wrenching column for the BMWMOA magazine ON, has over 300k miles on his 1150R as does his wife on her oilhead. He still travels on his , hers is occassional use now.
Posted: Mon May 16, 2011 6:10 pm
by Coyne67
Thanks Kantukid, good to know I knew it was a bargin when I found her and cant wait to get her out on the open road......and have been looing at the link you sent me Towerworker good info this is a great site for info from real bike riders cheers guys and girls
